Hi everyone.
This is my first post here after having my A3 for a while and being a member on other sites. I.m sorry if this has been done to death but i'm having a problem with a fault code.
after running a scan with vcds i'm getting this :- 1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 230639 km
Time Indication: 0
Date: 2015.11.27
Time: 15:27:55
I have today stripped out the loom from the front divers side, i found a couple of wires that had the outers rubbed through so i have taped them up,couldn't find anything that was broken so put it all back together but am still getting the same fault. Is it possible that i have a broken wire further down the loom away from the door pillar ? i have checked the other doors but they are all good as i'm guessing those doors don't get used as much as the drivers side. Am i missing something or is there somewhere else i should be looking ? I'd like to try and fix this before i lose the single wire that's keeping everything working. Also is there a way of checking each door using vcds ?
Thanks for any advice in advance. Matt.
