Thread: Driver electric window stuck and making horrible noise
Results 1 to 8 of 8
Hybrid View
  1. Driver electric window stuck and making horrible noise
    Dec 2013
    A, A
    Hi all,
    I am having an issue with the drivers side front window of my A6 1.9TDi 2003 avant. It makes a horrible noise and has a mind of it's own. Today it has gone down and I cannot get it back up again, it gets to a max of half way and there it stays. I took the door panel off and could see a load of plastic shavings in the bottom of the door, so it looks like something has eaten itself!
    Does anyone know how I can get the window up again manually?
    Dan
  2. Re: Driver electric window stuck and making horrible noise
    Jul 2007
    glasgow
    35 Post(s)
    if you look in door & see white plastic wheels in a channel, then go to Halfords and buy some white grease
    Put that in the channel .................... you may need to put window up/ down to do this , then try and get window up and down to lubricate these wheels
    Failing that, is the window regulator jammed or misaligned.
    Is the motor working ?
    Usually you can push & pull it up to jam with a piece of wood
  3. Re: Driver electric window stuck and making horrible noise
    Dec 2013
    A, A
    Thanks for your reply.
    I had a look and can't see any white wheels anywhere?
    Re the motor I think that is what is at fault as that's where the graunching noise is coming from. I am guessing that a cog or cogs have failed and the mechanism has eaten itself up? But the window cannot be lifted beyond half way, I can feel the cables are tight as hell and I am unable to physically move it any further up, but it will go down with under the motor's power
  4. Re: Driver electric window stuck and making horrible noise
    Dec 2007
    8 Post(s)
    It may be the steel cable which has frayed and fouling on white plastic pulley,
    Motor and pulley assy may need to be removed to loosen cable to allow window movement
    Then it will require a new regulator assy.
  5. Re: Driver electric window stuck and making horrible noise
    Dec 2013
    A, A
    Thanks for that. I'm have covered it for the evening and will take it to a friends garage to have a better look tomorrow morning. Is the cable part of the regulator assembly? I guess that the motor mechanism will be knackered too though...
  6. Re: Driver electric window stuck and making horrible noise
    Dec 2013
    A, A
    Hi all. I have had a good look on line and i think it is the motor/cable jamming. Bottom line is it won't get fixed today (need to order the parts and its going to be monsoon conditions today - awesome timing!!) so does any one know how I can get the window into the closed position without stripping the window frame down? If I can get the window back to closed I can at least drive around but at the moment I can't drive it in the wet lie it is
    Any thoughts appreciated
  7. Re: Driver electric window stuck and making horrible noise
    Dec 2007
    8 Post(s)
    I may be wrong,but I think the only way to get it moving up to the top is to remove the motor, then the plastic pulley unit ,or maybe cut the cable to allow the window
    to be lifted up manually and wedged in place. Maybe by cutting cable it is possible to leave motor in until you have replacement regulator
  8. Re: Driver electric window stuck and making horrible noise
    Dec 2013
    A, A
    Thanks for your reply. I was just starting to think about cutting the cable. I think that's the only way until I can replace the whole thing.
  1. Audi A4 2.0 FSI: Driver side window glass stuck
    By Tauri in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-08-2014, 10:58 AM
  2. Drivers Electric Window stuck down 98 sharan
    By gforce2k in forum Touran - Sharan - Caravelle
    Last Post: 09-03-2010, 03:16 PM
  3. Electric window stuck
    By VW NORTON in forum Golf MK4 - 1999 - 2004
    Last Post: 22-02-2010, 08:19 PM
  4. Electric window stuck in down position
    By gonzales2 in forum Golf MK4 - 1999 - 2004
    Last Post: 14-07-2008, 10:55 AM
  5. Urgent Help Needed !!! Driver Window Stuck Open
    By danielintheuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-03-2008, 06:17 PM
