Thread: 2003 sport quattro buying advice
  1. 2003 sport quattro buying advice
    Nov 2015
    Northants
    Hi Guys,
    I am about to go and look at a 1.9 tdi sport quattro 2003 with 120K. What are the important things to be looking for? Apologies if this has been gone over, if so a link would be great....
    Also assuming I go for it, I intend to give it a service.
    Thinking of changing, steering fluid, brake fluid, oil, Gear box fluid, fuel filter, oil filter, air filter. Any others worth changing? Anybody used Rock oil?
    I have read that the turbo can get clogged up so innotech cleaner can be used, worth a go?
    Any fluids to change on the quattro system?
    I intend to keep the car for a number of year, is the above being a bit OTT???
    Appreciate the advice.
  2. Re: 2003 sport quattro buying advice
    Jul 2015
    Staffs
    46 Post(s)
    pd 130?
    Gearboxes tend to like the genuine fluids. A good rear diff oil.
    Rusty front and rear arches. Rear wiper/washer. Damp interior.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: 2003 sport quattro buying advice
    Nov 2015
    Northants
    Quote Originally Posted by rowdy-999 View Post
    pd 130?
    What is the common cause of damp interior?
  4. Re: 2003 sport quattro buying advice
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by Maxster View Post
    Old, and incontinent drivers.
    Ian
  5. Re: 2003 sport quattro buying advice
    6 Post(s)
    2003 will be B6 model, not B5. No great shakes, it's personal preference, as they're cosmetic changes.
    As mentioned 120k miles is hardly run-in for a diesel, so as long as it's been well-cared for and serviced.
    At this mileage, then full suspension overhaul could be in the mix. Sure you can replace the arms as they fail, but a front-end refresh works wonders if you plan to keep it. Meyle HD or Lemforder, fit and forget. ARB bushes front and rear (if Avant) is inexpensive.
    Timing belt and auxilliary belts, then 75k miles or 5 years for 4-cylinder diesels. New water pump and thermostat at the same time.
    Turbos can fail, but unless you notice power slump, leave for the moment. EGR blank is advisable.
    Quattro drive is pretty robust. By all means replace rear diff gear oil. Allow 2 litres and use genuine VAG oil. Always release fill plug before releasing drain plug, just in case.
    Damp interiors, then if Avant check rear washer jet on wiper works. It can break at motor and water drains into rear tailgate, or breaks along flexible pipe. Another tell-tale is blocked drains in bulkhead (where battery sits).
    Service items, don't forget pollen filter (next to battery), new glow plugs (only remove if confident they won't break), otherwise it's head off time.
    2017 A4 Allroad Quattro Sport 3.0 TDI 272PS, (59k)
    2016 BMW i3 REx (80k)
  1. Buying advice please! A4 1.9 tdi Quattro Sport
    By Matt924 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-01-2012, 12:17 AM
  2. Please Help Audi A4 1.8T Quattro Sport - 02 plate - Buying Advice
    By dvoodoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-07-2011, 10:58 PM
  3. vw golf 1.4 2003 - buying advice
    By sdevine in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2011, 11:16 AM
  4. Advice on buying an 2003 A8 4.2
    By tonywilliams in forum A8 - S8 - V8
    Last Post: 02-03-2011, 09:49 PM
  5. Please Help A4 1.8T Sport Quattro Buying Advice
    By owl10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-01-2010, 09:32 PM
