Thread: Urgent help needed - headlights no high beam
  1. Urgent help needed - headlights no high beam
    Jun 2014
    West
    Evening all,
    my 2009 A6 Avant is with a local garage having a service, new shocks + springs and anti roll bars fitted. They have done the work and have now reported they need the car for longer because the front headlights don't have a high beam. Also the nearside brake light is not functioning.
    I've had a quick look on google and the most obvious thing is that they've either damaged or unplugged the level sensors for the xenons. The lights were functioning perfectly before it was given to them. What else could be the issue?
    All input appreciated.
  2. Re: Urgent help needed - headlights no high beam
    Jan 2011
    Stafford, UK
    If they have had the suspension apart, a good guess would be the level sensors for the xenons.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  3. Re: Urgent help needed - headlights no high beam
    Jun 2014
    West
    Quote Originally Posted by royclark View Post
    That's what I thought. Would damaging these cause the main beams to not work at all?
    Are these linked to the brake lights at all?
    My car has the auto high beam/high beam assist if that makes a difference.
  4. Re: Urgent help needed - headlights no high beam
    Nov 2012
    Somerset UK
    On my prefacelift the levelling has never worked but high beam works fine.
    None of the work you've listed done would necessitate taking the front bumper off.
    Nearside brake may be coincidental.
    Does this garage or indeed you have VCDS?
  5. Re: Urgent help needed - headlights no high beam
    Jan 2011
    Stafford, UK
    Not linked to the brake lights only xenons.
    If all was OK befor garage had it, take it back for them to solve and put right at their expense.
  6. Re: Urgent help needed - headlights no high beam
    Jun 2014
    West
    The garage still has the car and want to keep it to rectify. They've previously carried out work on my cars with no hassle so I'm giving them the benefit of doubt but we have a trip to make in the next couple of days so I wanted to give them some hints as to what the issue maybe.
    The full list of work as follows -
    Service - oil, air, cabin and fuel filter. Spark plugs and new coils.
    New shocks and springs. New anti roll bars with bushings.
    New rear brake hoses and bleed.
    The only thing that I can think of is the levelling sensor but I have little experience with Audi as this is my first. Seems strange unless there was a battery issue at some point which may have caused issue with relays etc.
    I'll call them again in the morning to discuss.
  7. Re: Urgent help needed - headlights no high beam
    Jun 2014
    West
    So the headlight issue has been sorted, the older tech who was checking the car after the work was carried out thought the "flash to pass" lights should come on with the high beam. Also the auto high beam was activated so the bi xenons didn't switch to high beam. A little embarrassing for him but all sorted on that front.
    However the outer rear LED on the NS is definitely not working, I plugged in VCDS and no errors. I'm assuming corroded connector but they're looking into it.
  1. Headlights stuck on full/high beam
    By hairyape1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2014, 09:53 PM
  2. Low beam headlights
    By Dave_Bounce in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2013, 02:56 PM
  3. Please Help Headlights - Beam Deflection
    By a4suction in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2009, 12:39 AM
  4. changing main beam headlights
    By alienkidmj12 in forum Passat - Archive Topics
    Last Post: 19-12-2007, 07:19 PM
  5. Dip beam headlights not working
    By deamie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-11-2007, 02:23 PM
