Thread: Clutch problem
  1. Clutch problem
    Oct 2015
    scunthorpe
    Clutch problem with sons car, it's a 1.9 tdi with 6 speed box.
    Previously we've changed the master cylinder and the pedal when clip broke. Now he's saying pedal is going to floor but then car lurches forward as though pressure has been lost, not losing fluid. Could this be seals passing in one of cylinders, if so which is most likely. Or could it be a thrust plate or bearing issue. Clutch isn't slipping at all.
  2. Re: Clutch problem
    Oct 2015
    GB
    Is the fluid level ok or its possibly air in system try bleeding it and topping up with fresh fluid if low.
    Sent from my SM-A300FU using Tapatalk
  1. Clutch problem
    By Hazmanscoop in forum Golf MK5 - 2004 - 2009
    Last Post: 18-10-2014, 09:22 AM
  2. Clutch problem
    By taximeistergolf in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-02-2011, 11:15 PM
  3. Please Help Clutch Problem Still
    By surreychris in forum Golf MK4 - 1999 - 2004
    Last Post: 19-01-2011, 11:32 PM
  4. Clutch Problem
    By K90zz in forum Golf MK4 - 1999 - 2004
    Last Post: 27-07-2008, 07:07 PM
  5. Please Help Clutch Problem, i think!
    By TWEET in forum Golf MK4 - 1999 - 2004
    Last Post: 17-05-2008, 10:25 AM
