Thread: cooling problem or air lock b6 1.9tdi
Results 1 to 10 of 14
  1. cooling problem or air lock b6 1.9tdi
    Nov 2015
    Derby,UK
    hi all i wonder if someone could help me in this long stressfull time of cooling problems,basiclly ive got no heat coming through vents,losing abit of coolant,engine never overheats,top hose is hot bottom is cold,changed thermostat 5 times and doesnt make any differance at all,ive tried bleeding it from the heater matrix but to no avail although when i pulled the pipe this morn there was no water coming out at all plus none returning to the expansion tank,the top hose isnt rock hard when hot and no usual signs of headgasket so i dont think its that,im wondering weather the rad is blocked,another faulty thermostat or water pump has packed up,ive looked for leaks and everything plus after a 50 mile drive the water in the expansion tank was only very slighty warm and there was no pressure at all when releasing the cap,this really is driving me up the wall any help will be very much appreciated thanks
  2. Re: cooling problem or air lock b6 1.9tdi
    Dec 2009
    southampton uk
    Are you using genuine stats? Others are often bad.What temp does it show?If you cant bleed the matrix it could well be blocked.Try flushing it with a hose
  3. Re: cooling problem or air lock b6 1.9tdi
    Nov 2015
    Derby,UK
    Hi mate thanks for the reply,the stats are from euro car parts so not genuine,I've flushed and back flushed the matrix till it runs clear and still no joy,temp goes upto 90 as it should and sits there never goes above or overheats
  4. Re: cooling problem or air lock b6 1.9tdi
    Dec 2009
    southampton uk
    ECP stat was the one that was bad but if it gets to 90 quickly yours seems OK.I have heard that its the small bores in the matrix that can block and flushing is then no good.
  5. Re: cooling problem or air lock b6 1.9tdi
    Aug 2011
    Meath
    Check the water pump impeller
  6. Re: cooling problem or air lock b6 1.9tdi
    7 Post(s)
    Quote Originally Posted by Doctle Odd View Post
    If you take the thermosat out you can stick your finger in and feel if the impeller is freewheeling or in bits.
  7. Re: cooling problem or air lock b6 1.9tdi
    Dec 2009
    southampton uk
    But it doesn't overheat so pump is OK
  8. Re: cooling problem or air lock b6 1.9tdi
    Jul 2015
    Staffs
    46 Post(s)
    Quote Originally Posted by mikeybutch View Post
    If the bottom hose is always cold ( even after a long run ) it must be over heating because there is no flow through the rad.
    Ian
    A4 B6 Avant Nogaro Blue
  9. Re: cooling problem or air lock b6 1.9tdi
    Aug 2011
    Meath
    Take Col's advice, remove the thermostat amd put your finger inside towards the impeller. I think the impeller is wonky or in many pieces through the cooling system. This is quite common with plastic pump impellers
  10. Re: cooling problem or air lock b6 1.9tdi
    Jun 2006
    Cardiff
    +1 for water pump.
    You should have flow from the headertank return pipe if the water pump is working, & the lack of pressure would also indicate pump failure.
    In the winter the bottom hose not getting hot is normal in my experience with VAG PD 130 engines. Both my Bora TDi's were like that & my A4 has been the same for the past 4 winters & 60k.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  1. How to bleed out air from the cooling system on a 1.9TDI?
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 29-01-2019, 02:28 AM
  2. 1.8t Air Lock / Cooling system issue
    By spellmaster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-06-2014, 10:36 PM
  3. Replies: 6
    Last Post: 15-06-2014, 09:28 PM
  4. 2002 1.9tdi, Air con compressor problem / Possible to repair?
    By hippo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 27-04-2013, 10:43 AM
  5. 2003 A6 1.9Tdi Air Con Problem
    By alanlush in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-05-2008, 03:10 PM
