Thread: GTTDI 150 Engine oil leak
  1. GTTDI 150 Engine oil leak
    Aug 2007
    Hi Guys,
    I have just replaced my sump, with an aftermarket part due to sump plug threads stripped. Unfortunatly I now have an oil leak from the rear area. This leak was NOT there previously. So I have removed it again and resealed and torqued, but leak still there The oil is dripping off the cover plate between the engine and gearbox casing at the rear of the engine. I cannot see were the leak is coming from Has anybody had similar ??? Thanks in advance, Med
  2. Re: GTTDI 150 Engine oil leak...............
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I haven't done it myself on that engine but I've heard you have to carefully guide the sump onto a couple of studs so as not to break the sealant bead and use the proper vw sealant.
  1. Cant cure air leak sound, help......GTTDi 150
    By scooter in forum Golf MK4 - 1999 - 2004
    Last Post: 06-07-2010, 09:01 PM
  2. Diesel Leak GTTDI 150
    By cosworthspeed10 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-04-2009, 07:52 PM
  3. Golf Gttdi 150 Which Oil Is Best
    By Michelin in forum Golf MK4 - 1999 - 2004
    Last Post: 07-01-2009, 08:10 PM
  4. Gear Oil For Gttdi 150???
    By tonyleach in forum Golf MK4 - 1999 - 2004
    Last Post: 03-12-2007, 10:47 AM
