Thread: Broken Springs - Replacement Options for S-Line Model
Results 1 to 10 of 16
  1. Broken Springs - Replacement Options for S-Line Model
    Nov 2015
    Sudbury, England
    After having my 2006 2.0TFSI S-Line Special Edition serviced by Audi 2 weeks ago I fully expected it to breeze through its MOT...
    Instead I was informed that I have 2 tyres on the legal limit and 2 broken rear springs .
    My dilemma now is do I replace all 4 springs for Eibach Pro Springs? And what sort of effect would they have on the stock S-Line shocks? As far as I am aware this will be a further drop of 5mm (from 25mm to 30mm) is this correct?
    Any advice or opinions will be greatly appreciated!
  2. Re: Broken Springs - Replacement Options for S-Line Model
    May 2012
    Everywhere
    308 Post(s)
    The Eibach with oe Bilstein B4 dampers will outshine your S line suspension both in terms of handling and ride comfort .
  3. Re: Broken Springs - Replacement Options for S-Line Model
    131 Post(s)
    1976 Post(s)
    If you wan to keep it as it is now, then genuine VAG springs only, if you have the time and a parts man who will do it, find out the EXACT spring details and see if Suplex or TRW do them. If you want firmer, go Eibach, there is NOTHING else like it.
  4. Re: Broken Springs - Replacement Options for S-Line Model
    Nov 2015
    Sudbury, England
    Thanks for the advice guys it's much appreciated!
    Had a look at Bilstein B4/Eibach Pro Springs combination and decided that I just can't afford/justify the extra cost as well as replacing the two front tyres. The things you have to sacrifice when saving for a house hey .
    The garage who did the MOT have quoted approx £315 for springs and fitting, that seems a little steep considering it is just the rear springs that need replacing? This seems like something I could probably do myself however would I need to get my wheels re-aligned after they are fitted?
  5. Re: Broken Springs - Replacement Options for S-Line Model
    131 Post(s)
    1976 Post(s)
    A4 8E rear springs are not easy at all, you either have to strip down the rear lower arms or use a special spring compressor to extract the springs.
  6. Re: Broken Springs - Replacement Options for S-Line Model
    46 Post(s)
    You on the wine yesterday? The car is a 8P A3
    Rear springs are a doddle, even I managed to do mine on my Sportback.
  7. Re: Broken Springs - Replacement Options for S-Line Model
    Nov 2015
    Sudbury, England
    Quote Originally Posted by Chris View Post
    Haha this did confuse me slightly! I am a newbie so thought i'd messed up haha
    Just waiting for Audi to get back to me on prices and then I'll give it a go myself. Thanks for your help!
  8. Re: Broken Springs - Replacement Options for S-Line Model
    46 Post(s)
    They can be done in less than 45 mins, even 30 if you're handy.
    Audi will charge over the top, buy genuine springs and let your local specialist/independent to fit them.
  9. Re: Broken Springs - Replacement Options for S-Line Model
    Nov 2015
    Sudbury, England
    Thanks for the reply Chris!
    Do you mean buy genuine springs from Audi? I have the colour code (3 grey spots 2 yellow spots) but can't seem to find them online?
    Will I need to get the rear wheels re-aligned after this or should it just be a simple swap?
  10. Re: Broken Springs - Replacement Options for S-Line Model
    Jan 2011
    East Kent
    I think Chris means to get your local specialist garage to order and fit genuine springs for you. You can buy the genuine springs from your local Audi dealer, TPS branch or no doubt through your local specialist garage.
    Any change to suspension components warrants a 4 wheel alignment + you are getting 2 new tyres so even more so.
    Previous: 2005 A3 1.9tdi SE
    2009 Audi A3 2.0tdi 138bhp SE
  1. Please Help Broken Springs
    By tpl288 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2011, 09:42 PM
  2. Suspension options: Springs & Dampers or Coilovers?
    By toff in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-02-2009, 09:18 PM
  3. Suspension replacement options for an S-line
    Last Post: 10-02-2009, 11:26 PM
  4. Broken Front Springs
    By gckimber in forum Superb
    Last Post: 26-05-2008, 09:25 PM
  5. broken turbo? options!
    By a6er in forum Archive posts
    Last Post: 26-09-2007, 11:40 PM
