Thread: 16395 error on vagcom
  1. 16395 error on vagcom
    Nov 2015
    Barcelona
    Hi there guys. I have a gti mk4 aum engine code, from 2002, and a couole days ago i got the engine check light, so i connected vcds to see what was the fault and got this error: 16395 - bank 1 camshaft a (intake) retard setpoint not reached (overachieved) and it says it might have something to do with the fuel pump relay, camshaft mechanical valve (n205) or timming belt. The car feels ok driving, starts right away and i dont really feel anythinf weird. Any ideas? Thanks beforehand guys!
    Sent from my A0001 using Tapatalk
  2. Re: 16395 error on vagcom
    Jun 2015
    GB
    http://www.audi-sport.net/xf/threads...-16395.126713/
    This might help you out
    Sent from my SM-N910F using Tapatalk
  3. Re: 16395 error on vagcom
    Nov 2015
    Barcelona
    Thanks dannyboy1987! It was worth reading, and hopefully i will be able to isolate what the problem is. I think its just the sensor broke, and hopefully by replacing it it will be fine, but lets see... Thanks pal!
  4. Re: 16395 error on vagcom
    Jun 2015
    GB
    👍no problem hopefully u manage to sort it. Post something once uv sorted it I'll be interested to know what it is because I have a AUM as well.
  5. Re: 16395 error on vagcom
    Nov 2015
    Barcelona
    Hi there again dannyboy1987. Well, so far, after clearing the error a few days ago everything is fine, no light on the dash/cluster, no error on vcds and car, as before, runs fine. Anyway, ill tell my mechanic to check the timing belt and camshaft just in case, as I have to replace the front silentblocks and rubber thing (cant remember the name in english ) on top of the front suspension, as i have a clonk/squeaky sound. Cheers pal
  6. Re: 16395 error on vagcom
    Jun 2015
    GB
    Glad to hear you have sorted your problem. 👍
  7. Re: 16395 error on vagcom
    Nov 2015
    Barcelona
    Yeah, lets see. Bad thing is my girlfriends ibiza 6l broke the belt almost stopped, heard a bang and wouldn't start again (witth wires it did, but of course no movement) so lets see how many €€€ :'( thanks pal
  1. VAGCOM Fault - 65535 - Internal Control Module Memory Error - 00-10 - Intermittent
    By Jay2013 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-04-2016, 12:46 PM
  2. Replies: 4
    Last Post: 27-12-2014, 04:26 PM
  3. Replies: 2
    Last Post: 25-12-2014, 11:59 AM
  4. Needle Lift Sensor - VAGCOM Error
    By Robnelson76 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-09-2012, 12:02 AM
  5. 00523 Error with VAGCOM
    By SYSTEMSEIKO in forum Archive posts
    Last Post: 19-05-2007, 04:03 AM
