Thread: Driver's Door lock button - will not lock with ignition on
  1. Driver's Door lock button - will not lock with ignition on
    Jan 2013
    Southampton, UK
    Appreciate if someone could confirm whether this is expected behaviour (and why if so).
    Audi A6 Avant BE - 2013.
    Driver's side internal door lock button opens all doors if pressed. If the lock button is pressed, the doors do not lock whilst the engine/ignition is on. With engine/ignition off, the lock button will lock all doors as expected.
    Automatic lock (if set on) works correctly when driving away from standstill.
    Thanks.
  2. Re: Driver's Door lock button - will not lock with ignition on
    Mar 2008
    Warwickshire
    No, I would expect the doors to both lock and unlock with each press with the engine on.
    Audi A6 (C7) 3.0 TDI S Line Quattro 245 Daytona Grey Sep 2013 -
    Audi A4 (B8) 2.0 TDI SE 143 Lava Grey 2008 - 2013
  3. Re: Driver's Door lock button - will not lock with ignition on
    Feb 2015
    Sligo, Ireland
    Mine works fine. Will lock and unlock with ignition on, off, engine running and not.
    Seems very odd that it won't let you lock it when the ignition is on.
    Kevin
  4. Re: Driver's Door lock button - will not lock with ignition on
    Jan 2013
    Southampton, UK
    Thanks for replies. I replaced the battery in the key (range appeared to be decreasing anyway), and am now getting expected results. Assume the two are linked....though maybe not.
  5. Re: Driver's Door lock button - will not lock with ignition on
    Apr 2011
    basingstoke,england
    12 Post(s)
    Very surprised today to get a message in the car, that my battery key needs replacing!!!.
    Technology eh😊
    Sent from my GT-I9505 using Tapatalk
    2016 A6 Avant 2.0 tdi Quattro Black Edition
    2013 A6 Avant 2.0 tdi Black Edition ​gone
    2010 A6 Avant 2.0 TDI Le Mans. gone.
  6. Re: Driver's Door lock button - will not lock with ignition on
    Jan 2013
    Southampton, UK
    Spoke too soon.....it's actually dependent on whether the headlights are on (and hence whether the door lock switch is illuminated). With headlights off, door lock button works as expected. With them on, can only unlock. Completely repeatable.
    Assuming there will be no direct link between whether the door lock switch is illuminated or not, I presume this is a bug in the car's software? I guess a dealer issue to resolve under warranty.
  1. Door lock button not locking and other electrical problems
    By EthanHD in forum Golf MK5 - 2004 - 2009
    Last Post: 25-10-2015, 06:54 PM
  2. Please Help Inner Driver Door Lock/Unlock Switch Button
    By kyszer in forum Touran - Sharan - Caravelle
    Last Post: 25-04-2014, 12:19 PM
  3. central locking button doesnt lock one door
    By richard2k84 in forum Polo - Derby - Lupo - Fox
    Last Post: 28-01-2013, 09:18 PM
  4. Replies: 0
    Last Post: 12-01-2012, 07:07 PM
  5. Please Help rear door wouldn't lock from inside (using 'lock' button)
    By angermayer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2011, 07:58 AM
