Thread: The steering is unsettled at low speeds following every ridge or imperfection
Results 1 to 10 of 20
  1. The steering is unsettled at low speeds following every ridge or imperfection
    Jul 2015
    Birchington, Kent, UK
    Hello guys,
    Trying to solve this one, I have changed the standard wheels from 16" 225 to 19" 255/35
    I also changed the SE springs with Eibach springs that lowered the car by 30mm ... nothing extreme there.
    I have done 4 wheel laser alignment.
    Yet the steering does pull a lot (tram lines) when it finds problematic roads ... this happens especially to speeds up to 50mph.
    On the motorway the car drives fine with no problems etc.
    The tires are standard (non run flats) 255/35 Pirelli P Zero Nero Rosso 96Y and they came from an RS4 about 4mm left on them, I put them on to see if I was happy with the ride etc when I changed the wheels. None of them had repairs ... or suspicious wear.
    Where shall I start looking? there are no suspesion noises and everything is tight.
    Is there a setting that needs to be changed via VCDS for the (Servotronic) steering rack when changing wheel dimensions? Or do I have to upgrade some bushes to the car with the "S6"? in order to get a better point and go...
    Has anyone had similar problem before?
    Vasilis.
    Audi A6 C6 2.4 V6 SE ('05) BMW 735i Individual M-Pack ('00)
    Lexus LS430 Premium ('01) Lexus GS300SE Navigator ('98)
    Toyota Prius T-Spirit ('04) Citroen Xantia 3.0 V6 Exclusive ('98)
  2. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Oct 2005
    As you've lowered the car and put on bigger wheels with wider tyres tramlining is your future I'm afraid.
    Edit:
    You're quite close to me too, the roads round here are terrible. I had a lowered Passat (45mm) on 15s and it was like driving a train at times. The A2/M2 was particularly bottom clenchingly terrible.
    You can try a tyre with a different/deeper tread pattern. The P Zero Nero is quite well known for tramlining.
    Adjusting the toe can help but you need to find someone willing to go outside of the normal manufacturer's settings. It takes a bit of time to get it right, so much so I gave up and learned to live with it (I'm a liar, I took the big wheels off!)
    0 3 0
  3. Re: The steering is unsettled at low speeds following every ridge or imperfection
    You have made no mention of the Offset E number. Regards Peter
  4. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Jul 2015
    Quote Originally Posted by Sam View Post
    Edit:
    I know I have done this with many of my previous cars , lower and change the wheels, but none was as bad as the A6... it is like the car is trying to kill you on the back B roads etc lol
    No problem on A2/M2/A299 though it drives fine once on the motorway move.
    I do have to agree the roads down here in Kent... are awful compared to the rest of the country
    I think I am due for a visit for a custom allignment with Wheels In Motion they would do any setting you like to improve the car. They had done this with my IS300 sportcross and the car was planted!
    Quote Originally Posted by Peter D View Post
    I assume you mean the alloys offset? 45 as you can see from the spec found on the boxes
    Attachment 28381
  5. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Jul 2015
    I would prefer to sell the car than go back to stock lol
    Before
    After
  6. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    Pros. Better ultimate lateral grip. Looks (subjective).
    Cons. Tramlining, harsh ride, road noise, more expensive tyres . And potholes / kerbs will kill your tyres.
    So if you regularly exceed 0.8g (lateral) and have an unlimited amount of dosh for tyres on the potholed roads of Kent stick with the 19s.
  7. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Jul 2015
    Quote Originally Posted by inspectorman63 View Post
    y the ride hasn't changed much and it does feel better.
    I do understand more expensive tires... but hey ho lol
  8. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    Welcome to the world of big tyres on the c6! Better known as the Le Mans spec!
    I have had my car for 2 yrs and still I feel the ride to be somewhat jarring. Strangely enough it's much better in wet.....
    I wondered if I too should Change my suspension, but I don't want any nasty surprises!
    I can't stand the ride, but a 2007 avant lemans looks badasss!
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
    0 2 0
  9. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Jul 2015
    Those who have 19" ... what tyres you think it will have less tramlining effect?
  10. Re: The steering is unsettled at low speeds following every ridge or imperfection
    Nov 2012
    Somerset UK
    lower profile/stiffer sidewall = tramlining
    The alternative would be to look for a tyre that has constant complaints of a weak/soft sidewall, but as you know that will have a significant downside in cornering, curb damage and wear rates, so is a swings/roundabouts think.
    I believe the Uniroyal rainsport 2, whilst great in the wet had a weak sidewall, now superceded by the RS3.
  1. Steering Shudder at low speeds
    By cunny67 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-03-2014, 09:26 PM
  2. Question Steering wheel vibration/shaking when rorating it on very low speeds and when parked.
    By vsheremeti in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2011, 11:21 PM
  3. Please Help Leon cuts-out at low speeds
    By CockneyScamp in forum Leon
    Last Post: 29-07-2009, 04:34 PM
  4. A3 Jerking At Low Speeds
    By Michael Schupp in forum Audi A3 - Archive Topics
    Last Post: 17-03-2009, 11:31 PM
  5. Instability while travelling at low speeds.
    By acoccoluto in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-12-2007, 10:00 AM
