Hi all,
i have a 2007 2.0tdi 170 sline with factory rear PDC. Intermittent fault traced to one sensor which was replaced but now it doesn't work at all. Get the soft beep on engaging reverse and that it. Had a local guy check for fault codes but all clear although he wasn't using VAGCOM so not sure if that would show and more detail ?
If if its needed any suggestions for someone in North Down who could help would be appreciated.
