Thread: Swapping headlights
Results 1 to 10 of 34
  1. Swapping headlights
    Dec 2005
    Hi
    I have SE trim with standard headlights without lens. I would like to swap them to the one with lens(not xenons). Can you tell me if it is plug and play? If not what needs to be done, any coding or the worst do I need audi components to be changed? Do I need any additional wiring? I was told that mine headlights come with 10pin socket and the others with 12pin. Is it true?
    What do I need to look at when buying from ebay?
    Any information would be welcome.
    Thank you
  2. Re: Swaping headlights
    Nov 2009
    46 Post(s)
    not a straight swap, wiring changes, coding changes and a possible bcm upgrade if yours isn't pinned for the shutter.
    if you say not xenons, which ones do you mean? the full led ones? you will also need headlight washer system.
  3. Re: Swaping headlights
    Dec 2005
    NO full LED one. With the lens on H7 bulb without the washer. Everybody says that if it is with lens it is Xenon. It looks like xenon but it is normal H7 headlight but with lens only. Like this
    Audi A6 S Line 2013 Left Driver Side DAY Time Running Head Light Damage | eBay
    Ignore that this one from LHD.
    It can not be so much complicated to change.
  4. Re: Swaping headlights
    Nov 2009
    46 Post(s)
    thats xenon and runs a d3s bulb.
    you still need the above in my first post however.
  5. Re: Swaping headlights
    Dec 2005
    is d3s bulb the same as H7 bulb. If not I am talking about the headlight that looks like xenon (with lens) but is with H7 bulb. Did you see thatsort of headlight in Audi C7? Like this car
    Audi A6 AVANT 2.0 TDI S Line 5dr Multitronic
    I believe if this car had xenons he would mention this in description but is not mentioned.
  6. Re: Swaping headlights
    Nov 2009
    46 Post(s)
    no d3s is not the same as h7. the d3s is a gas discharge bulb.
    the xenon light has a small inner bulb which acts as an all weather light which is a h7 bulb.
  7. Re: Swapping headlights
    Feb 2013
    Gloucester
    57 Post(s)
    Or if you have about 50 of them fitted in each side like factory fitted sets.
    Audi A7, S-line, 313 PS BiTDI Tiptronic, Daytona Grey, heated front and rear seats, Audi connect, quad zone climate control, ski chute and bag, Rear tints, 75 Litre fuel tank, All LED headlights, Night vision assistant, Rear view camera with corner view, Navigation plus, MMI touch, Heads up display, Adaptive Cruise control, Blind spot monitoring and active lane assist. Audi A5 (wifes) My Kit car blog - http://mitchsgbszero.blogspot.co.uk
  1. Question Swapping engines
    By doogham in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-05-2014, 07:47 AM
  2. Gearbox swapping.
    By blackie781 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-06-2012, 10:21 AM
  3. Swapping out the ashtray
    By topdrawer in forum Golf MK6 - 2009 - 2013
    Last Post: 09-07-2011, 05:21 PM
  4. is this worth swapping?
    By newb1e in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-12-2010, 02:49 AM
  5. swapping a cluster
    By dysdera in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2007, 08:26 PM
