Thread: MMI completely broken - what to do?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. MMI completely broken - what to do?
    Oct 2015
    Colchester
    So I got the mmi firmware and nav updates, which after a lot of faffing about, mainly because the instructions were written in the most appalling english and almost incomprehensible, I got installed and working. Whilst doing the activation sequence for the navigation, I opened the door to speak to our builder and when I got back in the car there was nothing. The car seems to work but there is no illumination of any of the mmi buttons, the screen won't appear and there is no audio. The display in the instrument cluster just says that "media/radio/navigation is initialising, please wait". I have used vcds and hopefully attached the log. There appears to be no communication with the radio or mmi, so is it totally ******?
    Any advice on what to do now?
    Code:
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Cannot be reached 0100
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 0100
    5F-Information Electr. -- Status: Cannot be reached 0100
    6C-Back-up Cam. -- Status: OK 0000
    Address 01: Engine (J623-CDUC)       Labels: 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0005
       Revision: 53H37---
       Coding: 12254012052601020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001005
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 2643284C5994C10E07-8072
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
       Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H10 0002
       Revision: --H10---    Serial number: 0000000813
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A02087
       ROD: EV_TCMDL501.rod
       VCID: 2C57DA644778FB5ED1-8078
    Address 03: ABS Brakes (J104)       Labels: 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Revision: --------    Serial number: --------------
       Coding: 27A68701E465E180DB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004028
       ROD: EV_ESPPremiAU57X_AU57.rod
       VCID: 3663F80C8934B18EB7-8062
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Component: BCM2 2.0      H31 0333
       Revision: 00002001
       Coding: 05B92F06000000000000
       VCID: 78FF3634CBA087FE65-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H39 0046
    Address 08: Auto HVAC (J255)       Labels: 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0063
       Serial number: 10121100040531
       Coding: 3622000828
       ASAM Dataset: EV_AirCondiBasisUDS 002039
       ROD: EV_AirCondiBasisUDS.rod
       VCID: 244732442FA8331E19-8070
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0100
       Revision: 20012002    Serial number: 00000001158569
       Coding: 2600201040349FE00181008380001D0C0F9DC70827090101000004602100
       VCID: 6DD11760B4E2325686-8038
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 111103  H35 0051
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H02 0002
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0050
       Revision: 11001001    Serial number: 55901133501384
       Coding: 280308
       ASAM Dataset: EV_EPHVA18AU57X0000 002005
       ROD: EV_EPHVA18AU57X0000.rod
       VCID: 3D71E720AC0262D676-8068
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG005X3E7
       Coding: 30323436313330303537554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_AU57.rod
       Crash sensor for side airbag; driver side:
       Serial number: 3575HRB40690U2UQ51EU
       Crash sensor for side airbag; front passenger side:
       Serial number: 3585HRB405V1082I28Q9
       Crash sensor for side airbag; rear; driver side:
       Serial number: 3515JRB405D0UFPU2PHM
       Crash sensor for side airbag; rear; passenger side:
       Serial number: 3525JRB405R0U8DG21AG
       Crash sensor for front airbag; driver side:
       Serial number: 3554VRB40530Q4PIOP27
       Crash sensor for front airbag; front passenger side:
       Serial number: 3564VRB40550Q4PIM17W
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
       Component: Lenks.Modul   H05 0201
       Revision: 00000000    Serial number: 20111208000516
       Coding: 000035
       VCID: 306FCE1463509FBEED-8064
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
       Component: TDieGb        H79 0416
       Revision: 25460175    Serial number: 658061111593041
       Coding: 33A610000B012600010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K.rod
       VCID: 3C77EA24B7186BDE41-8068
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000334386
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewUDS 001025
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3467C2049F48A39E89-8060
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790253129
       Voltage stabilizer:
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000019838886
       Coding: 00781B0000006001000001010101102030303232203232
       VCID: 77FD3508C6BE88866C-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA32011GS20
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA.rod
       VCID: 6BD5197882F63C6698-803E
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204E01620002080002
       Shop #: WSC 02312 785 00200
       VCID: 428B94DCDDFC1D2E0B-8016
    Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0028247094
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS.rod
       VCID: 326BC41C655CADAE9B-8066
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0164967097
       Coding: 013F0E2220B9041583200904000104000000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.006  H02 0007
       Coding: 901E00
       Subsystem 4 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.006  H02 0007
       Coding: 801E00
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41899BD0D8FA063612-8014
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
       Component: EPB-4         H03 0012
       Revision: --------    Serial number: 00000000184945
       ASAM Dataset: EV_ParkiBrake 001022
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 2A5BDC7C4D8CE56E23-807E
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Component: ....LWR12.... H02 0013
       Serial number: 111207-0004-006
       Coding: 1122A6101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
    Address 56: Radio
    Cannot be reached
    Address 5F: Information Electr.
    Cannot be reached
    Address 62: Door, Rear Left (J388)       Labels: None
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 448792C4C7E8131E39-8010
    Address 6C: Back-up Cam. (J928)       Labels: None
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0111
       Revision: 11001001    Serial number: 82330JF0017491
       Coding: 0202000001000100000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 005022
       ROD: EV_CamerSysteTopViewAUDI.rod
       VCID: 2B55D9784276FC66D8-807E
    Address 72: Door, Rear Right (J389)       Labels: None
       Component: TSG HR        H04 0212
  2. Re: MMI completely borked....what to do?
    Mar 2014
    Edinburgh
    235 Post(s)
    Is this on the facelift with the tech pack/mmi plus?
    If ignition isn't on and you open a door the car turns everything off. Not a good sign 5f isn't readable.
    If it's the facelift mmi plus you need to remember the update file is like 11-14gb and this can take forever to load so it might be still doing it in the background.
    First time I updated mine took over an hour so you might be lucky.
    Give a while and try doing the reboot on the mmi
  3. Re: MMI completely borked....what to do?
    Oct 2015
    Colchester
    The update for the firmware was done successfully first, then I did the navigation software successfully and it all went **** up when doing the activation for the navigation. Ignition was on, all electrics off and car was on a trickle charger.
  4. Re: MMI completely borked....what to do?
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    What year is your car? Where did you acquire the update discs/card from?
  5. Re: MMI completely borked....what to do?
    Mar 2014
    Edinburgh
    235 Post(s)
    Check the fuse. Sorry that's all I've got.
    Otherwise if it's under warranty then take it to dealers and let them sort it. It's very unlikely you fried the 5F unit
  6. Re: MMI completely borked....what to do?
    May 2014
    Darlington
    78 Post(s)
    There is a nav activation file that is doing the rounds on the internet that will brick the 5F unit, and the only way to get it back is to solder a serial connector on the main board on the 5F module and reload the firmware. This is the risk of doing your own firmware & map updates with files on the internet.
    Warranty may be out as the dealers will be able to check what is going on with the MMI modules, and can check if firmware has been ran on other ECU/MMI modules as it will not match what is on Audi database. Audi record all coding & firmware on every car that leaves the factory, and only a dealer can make changes to this database via VAS.
  7. Re: MMI completely borked....what to do?
    Oct 2015
    Colchester
    The car is a 2012 avant and I got the cards from an apparently reputable website that others on here have used.
  8. Re: MMI completely borked....what to do?
    Oct 2015
    Colchester
    Quote Originally Posted by B5NUT View Post
    So if the 5F unit is toasted will my local dealer be able to repair the damage or will they just quote for a new unit?
  9. Re: MMI completely borked....what to do?
    May 2014
    Darlington
    78 Post(s)
    If you have ran the activation file that I've seen on the internet that corrupts the 5F unit, then dealer will not be able to recover the unit, and will charge you for a replacement. (approx £2,000 looking at etka) Your best option is to get a replacement from ebay. If you send me a list of all the file on the activation image then I can confirm if it's the bad activation file that is doing the rounds on the internet.
    I would not trust these sites, they take your money and give you stuff they they have downloaded from sites like gps underground and then charge you for it. May as well do the research yourself, and save yourself a few quid.
  10. Re: MMI completely borked....what to do?
    Oct 2015
    Colchester
    How do I find out which part number I need?
  1. My car is completely messed up..
    By mojotimes in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-09-2014, 06:49 PM
  2. Replies: 25
    Last Post: 27-09-2012, 06:34 AM
  3. Completely on the edge...
    By firstvolkswagon in forum Golf MK4 - 1999 - 2004
    Last Post: 18-02-2012, 11:44 AM
  4. Question MMI System Completely Frozen
    By clayts247 in forum In Car Entertainment
    Last Post: 22-11-2010, 09:27 PM
  5. VW Jetta1.8T Completely Cuts Out
    By zeddrick in forum Jetta MK1 - 1980 - 1984
    Last Post: 21-08-2009, 03:08 PM
