Thread: Electric drivers seat won't lift or recline
  1. Electric drivers seat won't lift or recline
    Nov 2015
    Warrington
    The drivers seat on my A4 Cab won't move up or down and won;t recline, it does slide forwards and backwards fortunately.
    I can hear the relay click when I move the switch but it doesn't do anything. Due to this I suspect its motor related either dodgy connector or the motor knackered. (that's assuming that it is the same motor that raises and reclines)
    Can anyone help me with how to access the motor or if they have any other idea to try please?
  2. Re: Electric drivers seat won't lift or recline
    May 2007
    17 Post(s)
    Quote Originally Posted by karllap View Post
    No, it's two different motors and two different switches but same power supply & earth. On the seat adjuster switch there is a 4 pin connector with 2 red & 2 brown wires. Make sure both reds have 12V and both browns are good earths.
    If the supply & earths to the switch are OK, you can do a bypass test (bypassing the switch) to see if the motors are able to move the seat. If the seat moves then the switch must be faulty.
    Jim.
  3. Re: Electric drivers seat won't lift or recline
    Nov 2015
    Warrington
    Thanks, I'm hoping that the fact its two different motors is good news as the chances of both being faulty is pretty remote
    I'll give it a go later today and feedback
  1. Question Front left window lift (drivers side)
    By Switzz in forum Octavia
    Last Post: 08-08-2015, 05:13 AM
  2. Drivers seat won't slide back & forward
    By ColMac in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-08-2011, 11:51 AM
  3. Drivers seat stuck...back wont recline
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2009, 06:39 AM
  4. Please Help Seat won't lift as one of the internal wires is broken
    By ziggywash in forum Golf MK3 - 1993 - 1999
    Last Post: 10-05-2009, 07:20 PM
  5. Replies: 0
    Last Post: 07-03-2009, 06:21 PM
