Thread: 3 of my 4 calipers get brake fluid, not the last one
Results 1 to 10 of 15
  1. Exclamation 3 of my 4 calipers get brake fluid, not the last one
    Jul 2015
    Paris
    I have a Golf mk4 GTI 1.8t 2003.
    Some hard brake lines were broken (rust) so I've replaced 3 of them.
    I tried a full brake bleeding with my Power Bleeder, no problem with the front left/right and the rear right.....
    BUT ABSOLUTELY NOTHING from the Rear Left !!
    First I've checked the brake line disconnected from the caliper (maybe the caliper was faulty)
    ===> got 1 drop of fluid every 10-20 sec... )
    Then I thought that the brake line was bad So I bought 2 new one (from VW and a brake specialist) :
    =====> Same problem no fluid
    So if anyone can explain what could be the problem ?
    ABS pump, master cyl, the brake line ???
    I have VCDS if needed
    Thanks a lot
  2. Re: 3 of my 4 calipers get brake fluid, not the last one
    2019 Post(s)
    The hose to the rear caliper which is crimped to the line, is that new?
  3. Re: 3 of my 4 calipers get brake fluid, not the last one
    Jul 2015
    Paris
    Thanks for the reply.
    Everything is new x2
  4. Re: 3 of my 4 calipers get brake fluid, not the last one
    2019 Post(s)
    Did you use any line clamps on the rear caliper hoses? Can you get more fluid to flow by pressing the brake pedal? Do you have a system like VCDS that allows you to do basic settings on the ABS pump?
  5. Re: 3 of my 4 calipers get brake fluid, not the last one
    Pembrokeshire
    22 Post(s)
    follow the pipe back to the abs pump and see if you can get fluid if you just un nip that connector. ?
  6. Re: 3 of my 4 calipers get brake fluid, not the last one
    Jul 2015
    Paris
    No, I use only the same parts found on ETKA/ETSA and that's what I ordered and installed.
    Yes I have VCDS
    I'm going to swap the left rear with the left right brake line directly on the hydraulics unit
    I suppose :
    - fluid from left rear = hydraulics unics unit faulty
    - fluid from rear right = I bought bad brake lines
    Right ?
  7. Re: 3 of my 4 calipers get brake fluid, not the last one
    Jul 2015
    Paris
    Ok I'll see thanks
  8. Re: 3 of my 4 calipers get brake fluid, not the last one
    Jul 2015
    Paris
    Quote Originally Posted by zollaf View Post
    No fluid
    If I disconnect those from the master cyl for ex yes there is
  9. Re: 3 of my 4 calipers get brake fluid, not the last one
    2019 Post(s)
    Quote Originally Posted by DeadEye View Post
    They use different sized fittings, M10 and M12
  10. Re: 3 of my 4 calipers get brake fluid, not the last one
    Jul 2015
    Paris
    I know I've changed them myself
    M12 master cylinder
    M10 pipes to calipers
    It was just an example.
  1. Question Brake fluid, coolant, powers steering fluid.... advise please
    By IlovemyVW in forum Golf MK4 - 1999 - 2004
    Last Post: 17-11-2013, 07:43 PM
  2. Are A4 (B8) and A5 brake calipers the same?
    By pilot5054 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 03-01-2013, 07:37 AM
  3. Brake calipers
    By joedredd in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-01-2010, 06:30 PM
  4. Brake Calipers
    By Oggi1808 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2009, 06:28 AM
  5. Renew your brake fluid with OEM spec fluid!!!
    By cbrpaul in forum Chat - Anything with wheels
    Last Post: 01-10-2007, 01:54 PM
