Thread: 2.0 Tdi BRD white/blue smoke, stem seals?
Results 1 to 10 of 17
  1. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Dec 2009
    southampton uk
    If its seals you would see smoke all the time.How much oil does it use?If normal I wouldn't worry just monitor.Maybe some injector cleaner and a good hot run will help
  2. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    2022 Post(s)
    I have never ever seen stem seals or guides wear on the 2L 16v head. Whoever said it's a £500 job has never done one, £500 would cover the cost of removing and replacing the cam belt system and buy some of the parts but it is a LONG LONG way in from there to do the stem seals with the head on. firstly you have to find some way of pumping compressed air into the cylinders whilst you remove all 16 valve spring retainers one at a time.
    Getting an air line adapter into these glow plug holes can be a sketch, I made my own adapter.
    0 2 0
  3. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Oct 2015
    uk
    Very interested in how this goes as I also have a BRD with issues. I wouldn't say smoke but fumes, strong catch your throat fumes. My DPF has been removed but I smelt another 170 TDI with DPF removed today (it's a kink I am developing) same smell but not as strong as mine. I also know exactly what the OP is saying about the dipsticks, think it is probably not just BRDs but it's so hard to see exactly where the level is. Like the pictures above, I haven't seen inside my engine before so this is a first, where are the glow plugs?
  4. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    2022 Post(s)
    DPF removed cars are illegal AND in my experience emit a strong acrid smell that bites.
  5. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Apr 2014
    A, A
    The oil light comes on in car when it hits minimum on dipstick so can't see dipstick being at fault, even if it was the car burns oil all the way from max to minimum but smoking/butning oil less at near minimum
  6. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Pembrokeshire
    22 Post(s)
    to understand how valve stem seals leak you need to look back to old petrol engines. when you lift off the throttle there is a vacuum created in the inlet manifold which literally sucks oil in past the inlet valve seals. some older cars didn't even have seals on the exhaust valves as there is never and vacuum in the exhaust to cause the oil to be sucked in. now, look at your car, its a diesel so there is never any vacuum in the inlet anyway (apart from the shut off valve which operates for a second when you switch the engine off). its also turbocharged so the inlet runs at positive pressure for most of the time. the exhaust also runs positive pressure and oil will tend to not ever be drawn in through a valve seal. so i don't think your problem is valve stem oil seals. its either rings or the turbo seal, or a blocked breather or there is too much oil in the sump.
  7. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    In your OP you say they checked the turbo intercooler pipes which ruled out turbo seals, but that is only on the compressor side, what about the exhaust turbine side? It sounds like you are getting wet oil out the exhaust rather than blue smoke from oil burnt in the engine from passing oil rings on the pistons or stem seals. You'd need to drop the exhaust off the turbine casing to see. I know a few folks who've had to replace the turbos on 2 litre engine around that sort of mileage.
  8. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Pembrokeshire
    22 Post(s)
    incidentally, you can identify a car with leaky stem seals if you drive behind it. every gear change produces a puff of smoke and accelerating off a roundabout (after slowing down, off throttle) produces a big puff of smoke. this applies to petrol cars, usually old bl mini,s or maxi's.
  9. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Apr 2014
    A, A
    I'll get the mechanic to get exhaust off to check turbo on compressor side
    It's been pressure tested so wouldn't that rule out rings
    would you recommend leaving it then since its under the max oil consumption?
  10. Re: 2.0 Tdi BRD white/blue smoke, stem seals?
    Apr 2014
    A, A
    He did say £500 minimum ��...you can smell the oil burning all the time even when engines warm, but just can't see the smoke when its warmed up,
    it's gone from max to min on the dipstick in 3k miles/3 months with no obvious oil leaks in engine bay either
    If i left it wouldn't it damage the DPF and CAT with the excess oil?,
    While the exhuast is cold if you start it up after 30 seconds or so put your hand in the exhaust and oil covers your hand...drive till its warmed up and park up again and wait for exhaust to go cold and put your hand in exhaust theres no oil
  1. Blue/White Smoke on startup and idle everytime
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2014, 11:12 AM
  2. White/blue smelly smoke! HELP!!!
    By PASSAT-UK-82 in forum Touran - Sharan - Caravelle
    Last Post: 10-08-2014, 11:41 AM
  3. valve stem seals
    By lee58uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-11-2011, 07:41 PM
  4. Please Help White smoke - turbo seals and cost?
    By Scatman in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-04-2010, 03:24 PM
  5. white/blue smoke - head gasket?
    By ritter1 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-02-2009, 10:31 PM
