Thread: My Golf mk3 1.4 revs erratically when i drive it
  1. Unhappy My Golf mk3 1.4 revs erratically when i drive it
    Apr 2007
    My golf 1.4 has recently had a new fan switch and thermostat because the car was overheating. During it's time when it was overheating the revs on the car would begin behaving erratically when i was driving and would occur as the car crept over 100 degrees. Now i've had the above various replacements my car still revs erratically but when the temperature is around 90 degrees.
    Can anyone tell me why this is happening still as the car no longer overheats but still seams to share some of it's overheating tendencies? I'm really puzzled!
    thanks
    Stuart
  2. Re: My Golf mk3 1.4 revs erratically when i drive it
    Sep 2007
    When you say erratic idling does it range from about 700 to 1600 rpm ?
    If so then my 1.8 was doing the same and I replaced the temp sensor (the sensor with 4 wires going to it on what looks like a thermostat housing on the front (top) of the engine.
  3. Re: My Golf mk3 1.4 revs erratically when i drive it
    Apr 2007
    700-2500rpm. It completely takes over the car. I then put in neutral it starts to calm down, but i've normally pulled over by then.
    Did it ever eventually cause your car to rev low enough and drop to the point that it cuts out, then refuses to start straight away? Maybe have to wait 15-20 mins to starts again?
  1. Golf Mk4 GTI 150 Sticking Revs
    By littlecham in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2010, 11:46 AM
  2. low revs on cold start -golf mk3 1.8
    By noho in forum Golf MK3 - 1993 - 1999
    Last Post: 20-08-2009, 05:38 PM
  3. Golf Mk4 1.6 Revs Fluctuate / stalls / temp up & down!!
    By randall977 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-04-2007, 01:29 PM
  4. Mk 3 Golf - Loud Knocking and No Drive
    By steve.sawyer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-01-2007, 11:33 PM
  5. MK3 golf gti hub/drive shaft nut
    By pants78 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-01-2007, 12:27 AM
