Re: Tyre Pressures Dropping –
29-10-2015,12:26 AM
My allroad BiTdi was an early July collection 2 years ago when the temps were in the 30C range. Late in September or early Oct that year I headed off one morning when temps were much lower (in the 12C range if I recall) and has a "check tyre pressures" warning - for all 4. Sure enough they were all down by some amount (cannot remember) and I put it down to the change in ambient temps causing a drop in pressure. However, once rectified the problem did not reappear.
The fronts being down another 3 psi after 6 weeks could be temp changes again but the rears dropping as much as they have would be a worry. However one thing does concern me - the heat that you mention from the rear wheels. That's not right. One issue with that is that you may have re-inflated your rears when they were warm - so you thought you'd stuck 33psi or whatever in but when they cool they are down to 28psi. It takes a little while for the automatic pressure sensor to "see" a pressure change issue so if they are warming up rapidly when you drive it could mask that discrepancy.
A couple of things I would suggest.
- Leave the car sitting so all tyres are cold and re-inflate to correct pressures. Ideally you want to do this on your driveway at home after the car has sat overnight and use a separate digital pressure gauge - don't rely on the crap that is built into foot pumps usually. If you need to take it to a garage cos you don't have a foot pump etc. then make it a short trip and check the tyre temps so you understand if it's causing a discrepancy.
- You need to get to the bottom of the heat you are sensing from the rear tyres. Assuming it's happening even with moderate driving - and based on the assumption that you do a lot of start stop driving because you are in London - I'd suggest switching off the driver aids that automatically apply the brakes. So always manually disengage the handbrake by pressing the button before pulling away and turn off the hills assist auto brake thing. You really don't need it in an auto anyway and there have been accusation (Honest John etc.) that those systems cause excessive rear pad wear - which would also generate heat.
Beyond that take it back to the dealer and ask them to investigate.
A6 allroad BiTdi (MY14, July 2013 - DAB & power tailgate). Glacier white, tech pack (HDD Nav, colour DIS, Parking Plus), sports seats, 4 zone climate, heated seats front and rear, ambient lighting, 75L fuel tank, adaptive Bi Xenon headlights
