Thread: Installed DAB now MMI not working.
  1. Installed DAB now MMI not working.
    Nov 2014
    gravesend
    Car is audi a6 c6 sline 3.0tdi 2005 .Installed a DAB radio module (kenwood audi original unit) never had a DAB aerial but booted it up anyway.Showed DAB on MMI screen but no signal due to no aerial .The car was then left in garage for couple of days where battery went flat so charged it up.Got DAB stick on window aerial so put that on and plugged into DAB unit.Went to try it out and bugger all,no MMI display apart from start up screen and no lights on the MMI consule buttons.What have i done wrong.Tried MMI reboot nothing ,toke of battery for 1hr the same.I did put another satnav module in about a month ago but that worked right up until i installed DAB.Re checked all the cables plus MOST cabled that had to be linked up to original ones but still nothing.Did notice though i unplugged the MOST optic cables from the amp and found one of them would flash red but the nav optic and DAB most optic does not but when i changed the nav unit a while back im sure i see it flashing then.I also unplugged the MOST optic cable from the CD player in the dash that did not flash until i wiggaled the cable about then stopped again.
    Can someone put me on the right path hear thank you.
    Here is the latest vagcom readout.
    Code:
    Sunday,18,October,2015,18:22:41:30570
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0 (x64)
    Data version: 20140905
    VIN: WAUZZZ4F05N121036   License Plate: WRFEFVWWWWW
    Mileage: 214590km-133340mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53
              56 61 62 72 76
    VIN: WAUZZZ4F05N121036   Mileage: 214590km/133340miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Cannot be reached 1100
    0E-Media Player 1 -- Status: Cannot be reached 1100
    0F-Digital Radio -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Cannot be reached 1100
    47-Sound System -- Status: Cannot be reached 1100
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    61-Battery Regul. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4F0 910 401 A    HW: 4F0 907 401 B
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H01---    Serial number:
       Coding: 0011372
       Shop #: WSC 02334 785 00200
       VCID: 1A3DA22AD5E8D3CE759-804F
    2 Faults Found:
    005661 - Glowplug for Cylinder 4 (Q13)
                   P161D - 001 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 0
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 214590 km
                        Time Indication: 0
                        Date: 2005.02.04
                        Time: 05:08:57
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 237.9 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 12.77 V
                        Duty Cycle: 15.0 %
                        Temperature: 15.3°C
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 002 -
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 0
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 214590 km
                        Time Indication: 0
                        Date: 2005.02.01
                        Time: 12:01:44
                 Freeze Frame:
                        RPM: 0 /min
                        Torque: 249.6 Nm
                        Speed: 0.0 km/h
                        Duty Cycle: 1.0 %
                        Voltage: 11.63 V
                        Bin. Bits: 00101100
                        Torque: 93.6 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans        Labels: 09L-927-760.lbl
       Part No SW: 4F0 910 156 H    HW: 09L 927 156
       Component: AG6 09L 3.0lTDI RdW 0110
       Revision: --H01---    Serial number:        ’’’’’’’
       Coding: 0000001
       Shop #: WSC 00000 000 00000
       VCID: 285988E29B84715EF3D-807D
    No fault code found.
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H03 0090
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020876
       Shop #: WSC 02327 785 00200
       VCID: 2D5779F6B466547600B-8078
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H30 0220
       Revision: 31050601    Serial number: 10600300161808
       Coding: 0000019
       Shop #: WSC 00029 210 86049
       VCID: E3C35FCE2222520666F-80B6
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H44 0070
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H39 0040
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F2 820 043 C
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000025    Serial number: 00000000136925
       Coding: 0001142
       VCID: DBB3672E1A526AC62EF-808E
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 B    HW: 4F0 907 279 B
       Component: ILM Fahrer      H14 0080
       Coding: 0010101
       Shop #: WSC 02335 785 00200
       VCID: 285988E29B84715EF3D-FFFF
       Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0150
       Coding: 00062736
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH10 0050
       Coding: 00141886
       Shop #: WSC 02335
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 C    HW: 4F0 959 655 B
       Component: 3E AIRBAG AUDI8RH29 0230
       Revision: 06H29000    Serial number: 0037LD06TYWG
       Coding: 0013125
       VCID: 275B8BDE969A7E26FA7-8072
       Subsystem 1 - Serial number: 6332CSME09640F0E9
       Subsystem 2 - Serial number: 6342CSME097E0B036
       Subsystem 3 - Serial number: 6351HSME072E037FF
       Subsystem 4 - Serial number: 6361HSME067754254
       Subsystem 5 - Serial number: 6371VSME06656172G
       Subsystem 6 - Serial number: 6381VSME066F1A2C-
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026051090176
       Coding: 0102141
       Shop #: WSC 02323 785 00200
       VCID: E6C546DAD110272E811-80B3
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: Lenkradmodul    H07 0080
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
       Component: KOMBIINSTR. M73 H15 0630
       Revision: 01000000    Serial number: 4PX312L45
       Coding: 2049403
       Shop #: WSC 54064 067 57207
       VCID: 214F95C6F8BE8016B43-8074
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 120080542381A2
       Coding: ECFE53C41B2904
       Shop #: WSC 02325 785 00200
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00-00000
       Coding: 0002590
       VCID: 295F8DE6808E4856EC3-807C
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
       Component: Komfortgeraet   H15 0100
       Revision: 01000015    Serial number: 01003890990000
       Coding: 0002547
       VCID: 2C5174F28F7C5D7E175-8079
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H10 0050
       Revision:             Serial number: 00000000087648
       Coding: 0001103
       VCID: DEB56E3A09407FEE491-808B
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00-00000
       Coding: 0002590
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000321
       VCID: DDB76936044664F650B-8088
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000026405
       Shop #: WSC 23352 823 63062
       VCID: 23439FCEE2A29206A6F-8076
       Subsystem 1 - Part No: 4F0 915 105 DL
       Component: von VA0  311217H14Q
       Coding: 344630393135313035444C56413033313132313748313451
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H11 0030
       Coding: 0002590
       VCID: E9DF4DE6C00E0856AC3-80BC
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H11 0030
       Coding: 0002590
    Address 76: Park Assist        Labels: 4Fx-910-283.lbl
       Part No SW: 4F0 910 283 A    HW: 4F0 919 283 A
       Component: Parkhilfe 8-Kan H12 0030
       Revision: 06.02.48    Serial number: 00067811820510
       Coding: 0001106
       Shop #: WSC 131071 1023 2097151
       VCID: 224D9ACAFDB89B0EAD9-8077
    End   ---------------------------------------------------------------------
  2. Re: Installed DAB now MMI not working.
    46 Post(s)
    Ok so everything on your MOST loop is not communicating. I would be double checking everything you've unplugged is plugged in securely. You might've bent a fibre cable and killed the system. You should've only disconnected the cables coming out of the amp or dvd drive as that's where you place the splitter cables.
    Which harness did you use?
  3. Re: Installed DAB now MMI not working.
    Nov 2014
    gravesend
    I harnessed it onto the satnav player Chris.
  4. Re: Installed DAB now MMI not working.
    Nov 2014
    gravesend
    right does anyone no where the optic cable first connects to.Got a feeling i might have to lay new optic cable from front to back .Got red light flashing from the multi cd player in glove box after that nothing flashing from any components in the rear.satnav,amp,dab units.
  5. Re: Installed DAB now MMI not working.
    Feb 2013
    Hants
    Shouldn't matter which is first but the system works as a ring so if any unit is not working or not powered up the whole system doesn't work. The light goes out from one unit to the input of the next unit and so on. If the new MOST cable is not connected up correctly it will mean none of the components will work correctly.
  6. Re: Installed DAB now MMI not working.
    Nov 2014
    gravesend
    Thank everyone for yer help.Found the prob with mine but might help to share as this could happen to someone else.The power /speaker cables that go into the large purple clip plug that goes into the amp in the boot left hand side have worked their way loose ,causing the power to be intermittent this made the MMI unit shut down .I made sure all the connectors where home and lovely a working MMI again.
  1. DAB Retrofit to MMI 2G High .. Done! (again!)
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-10-2017, 07:19 PM
  2. Thule throwbar, module water damaged, new one installed - Not working
    By JonasNJ in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-11-2014, 10:09 PM
  3. Radio is not installed message on MMI
    By mhurer in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-08-2012, 09:20 PM
  4. bluetooth installed working fine but cd changer option now greyed out ? any ideas
    By trapster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2011, 11:10 AM
  5. MMI tells me things are not installed!
    By Nomis Egnar in forum In Car Entertainment
    Last Post: 01-07-2009, 07:41 PM
