Thread: C5 2.5tdi Avant not starting
  1. C5 2.5tdi Avant not starting
    Feb 2014
    Pulborough
    Can anyone help.
    I have a C5 2.5tdi that refuses to start. Initially I changed one of the fuel return lines on the right bank middle cylinder. Car ran fine for 20mins or so to check for leaks. I went on a test run and got about 200yds and it died. Had it recovered and checked all obvious points. I.e. Fuel in filter body-OK, fuel at injectors-OK, but I did notice no fuel pump noise from the tank. Checked fuse OK, removed fuse (No 28) and applied +12v to jump pump and it does come on. Fuel relay is working can hear and feel it( also removed it and tested on bench). VAG diag tool brought up following errors-
    00542 G80 needle lift sensor
    00575 Intake manifold pressure sporadic regulating limit
    01376 Engine speed signal/inj pump sporadic defective
    01206 Signal for duration of ignition off static implausable signal
    I've changed the engine speed sensor on the block just to see if it was that (cheapest item first) but made no difference.
    Anyone got any ideas what I should be looking at? Dont want to start ripping out injector pumps etc until I know I'm looking at the right bits?!
    Cheers Noggin61
  2. Re: C5 2.5tdi Avant not starting
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    The fuel pump inside the tank does not push the fuel up to the injection pump It Just compare the amount of fuel between the two sides in the tank, and it works only when you have less than half a tank (from 2004 and below)The Injection pump sucks the fuel from the tank. Check for air in the clear fuel tube Between fuel filter and the injection pump.
  3. Re: C5 2.5tdi Avant not starting
    Feb 2014
    Pulborough
    Thanks for the quick reply I'll go and give it a go now
  4. Re: C5 2.5tdi Avant not starting
    Feb 2014
    Pulborough
    Disappointingly found fuel in the pipe so still struggling.
  5. Re: C5 2.5tdi Avant not starting
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Since the last thing you did was fuel system service I was betting on the air in the fuel system. about the G80 Check his resistance You should get about 100 ohms
  6. Re: C5 2.5tdi Avant not starting
    Feb 2014
    Pulborough
    Thanks again, I'm going back to basics and will bleed fuel system, probably Wednesday now as working away.
  1. Audi 2.5TDI not starting
    By chestykoff in forum New Member Introductions
    Last Post: 18-05-2010, 11:50 AM
  2. A4 2.5TDI - Starting Problems
    By ians63 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-10-2009, 11:47 AM
  3. 2.5tdi not starting
    By astrorogan in forum The Commercial Range
    Last Post: 29-08-2009, 12:47 AM
  4. 01 A4 2.5tdi Problem Starting
    By whoop whoop in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2009, 01:06 AM
  5. A4 2.5tdi starting problems
    By Pat in forum Archive posts
    Last Post: 18-04-2007, 01:15 PM
