Thread: bolts/studs for alloy wheel upgrade?
  1. bolts/studs for alloy wheel upgrade?
    Jun 2006
    HI, I am currently doing up a 86 polo and have bought some alloys to replace the steal wheels, they are original vw. Will I need the correctly tapered bolts for vw alloy wheels or are the original bolts from the steal wheels tapered for alloy wheels?
    Aug 2006
    Had the same prob with my other car (1987 Merc cosworth) when I fitted replacement Merc alloys - mine did require a tapered bolt. Best suggestion is go to your local alloy wheel/tyre shop where they be able measure the bolts and tell you the degree of taper on the existing bolts and which sort of bolts the alloys will need (usually for free) - I had to buy new bolts because the taper I had was wrong - they cost me around £10 for a set of 4 bolts (plus a set of locking nuts) - One tip they told me is that the bolt should always have a minimum of 7 complete turns for safety - Also be cautious of long bolts as these may go right through the hub and damage brake components behind it
    hope this helps!
  1. Golf MK4 alloy wheel size?
    By leemasiuk in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2010, 09:55 PM
  2. Do I need new wheel bolts ?
    By martinrhodes in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-04-2007, 08:26 PM
  3. alloy wheel cleaner
    By steveh in forum Archive posts
    Last Post: 07-03-2007, 09:21 AM
  4. ALLOY WHEEL 'UP-GRADE'
    By rottenronnie in forum Passat - Archive Topics
    Last Post: 06-09-2006, 11:37 AM
  5. Ronal alloy wheel problem
    By ajsphead in forum 100 - 200 - Turbo - 100 S4
    Last Post: 19-06-2006, 06:16 PM
