Thread: 6n2 polo cable type gear linkage
  1. 6n2 polo cable type gear linkage
    Oct 2015
    Cork City
    Hi lads. My 6n2 polo has a bit of bother selecting 1st and reveres gears.
    The haynes manual says it requires a special jig to be adjusted. Iv done a search here and found the YouTube video on adjusting the cable type vw gear linkages, but my gear lever doesn't have any slot for fixing it into position with a 5mm Allen key for adjustment. Should I have one? Is there a part missing or broken from mine would you think?
  2. Re: 6n2 polo cable type gear linkage
    Jul 2007
    glasgow
    35 Post(s)
    I think the most important part is locking at the gearbox.
    In neutral, the gearstick should be between 2nd and 3rd gear.
    I just locked the mechanism at the gearbox, pulled and turned the spring anti clockwise on the rods to lock in. There are 3 plastic lugs that attach to the metal threads. Carefully prise them off as likely rusted on.
    Clean the threads with a wire brush, oil up with 3 in 1 oil and maybe a dab of grease on it.
    Re-assemble and then it may take you several attempts to align the gears properly, it took myself 3 times until I was satisfied.
    You may want to consider changing the gearbox oil, I did it on my wifes skoda fabia, and its like a new car ................. cheap too if you DIY
  3. Re: 6n2 polo cable type gear linkage
    Oct 2015
    Cork City
    Thanks Nial I'll give that a go! Cheers mate!
  1. 6n2 polo gear linkage/cable set required
    By goe555 in forum Polo - Derby - Lupo - Fox
    Last Post: 04-03-2015, 09:18 PM
  2. gear issue vw polo 6n2
    By M3rlin in forum Polo - Derby - Lupo - Fox
    Last Post: 12-01-2015, 07:48 PM
  3. polo 6n2 sloppy gear change
    Last Post: 07-01-2015, 11:25 PM
  4. 9n polo gear linkage
    By bigplum in forum Polo - Derby - Lupo - Fox
    Last Post: 13-07-2010, 05:37 PM
  5. Gear Linkage
    By sgti in forum Bora - 1998 - 2005
    Last Post: 20-02-2009, 06:20 PM
