Thread: Ecu p/n - 038 906 019 kj - help
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Ecu p/n - 038 906 019 kj - help
    Jul 2009
    Leicester
    I've located and USED ecu with the same part number, but now I need to get the PIN from it.
    1. If I'm to plug the USED ecu (yes there will be a error regarding the immobiliser), but using a Vag K+ Can cable read the PIN number
    2. Use the Ross-Tech Vag-Com cable to sync the USED ecu (Immobilizer III ECU Swapping - Ross-Tech Wiki)
    Any other way I can obtain the PIN of the USED ecu?
    T3J
    VW Golf MK7 GTD DSG 2.0TDi Engine CUNA (2016)
    VW Golf MK7 Match Edition 1.6TDi BMT Engine CXXB (2016)
    VW Passat Estate Sport Tech 2.0TDi 170bhp Engine CFGB (2011)
  2. Re: Ecu p/n - 038 906 019 kj - help
    135 Post(s)
    2026 Post(s)
    You are trying to re-invent the wheel. To buy the VAG Tacho system that allows you to extract the PIN from a used ECU is thousands of pounds to buy legally and then you need a legally purchased full VCDS cable. Either get a mobile key specialist to come out and do it or take the car with new ECU to a VW dealer who will do it for you. Take the wipers and scuttle trim off first to save you money plus it stops you getting back into the car at the dealer only to find they have cracked the windscreen for you but nobody knows nuffin about it M8, like it when it came in ini't
  3. Re: Ecu p/n - 038 906 019 kj - help
    Jul 2009
    Leicester
    Hi Crasher
    Just like to say thanks for all your advice regarding topic title, used ecu is in and has solved my problems highlighted earlier.
    T3J
  4. Re: Ecu p/n - 038 906 019 kj - help
    135 Post(s)
    2026 Post(s)
    Thanks for telling us, it is information that could come in handy one day. How did you get the coding done?
  5. Re: Ecu p/n - 038 906 019 kj - help
    Jul 2009
    Leicester
    T3J
    1 1 0
  1. 2.5TDi Diesel ECU repaired - still showing ECU fault
    By wanstronian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-09-2012, 05:32 PM
  2. 1k0 906 093e
    By RichardSEL in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-06-2012, 12:53 PM
  3. 038 906 018 bp wiring diagram
    By audia4lyn in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-04-2010, 02:52 PM
  4. T4 Ecu
    By gunner100 in forum Touran - Sharan - Caravelle
    Last Post: 17-01-2009, 03:06 PM
  5. DOES MY ECU NEED RESETTING??can you even reset an ecu??!!!
    By slim1986 in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2008, 11:29 PM
