Thread: loads of errors help
  1. loads of errors help
    Jun 2009
    uk
    need help with alot of faults on my aud a4 b6
    Tuesday,06,October,2015,17:33:47:58797
    VCDS Version: Release 11.11.5
    Data version: 20121222
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E82A046414 Mileage: 230990km/143530miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 FP
    Component: 1,9l R4 EDC 0000SG 1467
    Coding: 00002
    Shop #: WSC 63351
    VCID: 6AD1A95D169A44489F8
    WAUZZZ8E82A046414 AUZ6Z0A0119039
    2 Faults Found:
    17994 - Engine Mount Solenoid Valves (N144/N145)
    P1586 - 35-10 - Short to Plus - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - Intermittent
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 1326
    Coding: 04255
    Shop #: WSC 06435
    VCID: E5CB5A617F84EB3032A
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    30-00 - Open or Short to Plus
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043
    Component: A4 Klimaautomat 0711
    Coding: 00000
    Shop #: WSC 63351
    VCID: DEB9758D5AD2B8E8F30
    No fault code found.
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279
    Component: int. Lastmodul RDW 0510
    Coding: 00001
    Shop #: WSC 63351
    VCID: EFE73849AD782160486
    1 Fault Found:
    01326 - Control Module for Multi-Function Steering Wheel (J453)
    49-10 - No Communications - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
  2. Re: loads of errors help
    Jun 2009
    uk
    my abs and esp light is on cleaned the sensor cant see a break in the wire should i replace the sensor with a new one??
    and are some of the other faults linked to the esp and abs ??
    thanks
  3. Re: loads of errors help
    chester
    17 Post(s)
    Jack it up and spin the wheel and look at measuring blocks you'll get the 4 wheels speeds,see if its showing any movement,remove the connector and look for crud,do a ohms test on the sensor see if its open circuit.the engine mount is very common,ignore unless you're a stickler for correctness.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  4. Re: loads of errors help
    Jun 2009
    uk
    Quote Originally Posted by nevo View Post
    what should the measuring blocks be reading??
  5. Re: loads of errors help
    chester
    17 Post(s)
    Wheel speed.
  1. New HU.. loads of questions!!
    By RexMundo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-01-2011, 07:33 PM
  2. HELP loads of queries
    By bond007 in forum In Car Entertainment
    Last Post: 10-05-2010, 03:33 PM
  3. A4 -1.8t USING LOADS OF FUEL
    By MCCLATCHIE in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-03-2010, 07:08 PM
  4. loads of problems
    By Kieronw3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-03-2008, 09:54 AM
