Thread: diagnostics
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. Angry diagnostics
    Norwich
    Please can any body tell me if i have a canbus diagnostic port in my 2003 1.9 tdi avant. i have bought cable of ebay no canbus support or k line support,wil not run ross tech 409.1 software .Any one knows where to buy correct diagnostic leads.
  2. Re: diagnostics
    Apr 2007
    Lancashire
    I dont think vagcom version 409 will work with an older opto-coupler type lead.
    You could try using version 311
    http://www.ross-tech.net/vag-com/dow...lease3112n.exe
    I have purchased a few leads on ebay, and all have been at least 'KKL'.
    Forum member 'Eshrules' sells discounted serial & USB leads.
  3. Red face Re: diagnostics
    Norwich
    sorry for being thick!But is it still a can -bus lead i need. thanks for your help
  4. Re: diagnostics
    Apr 2007
    Lancashire
    I think you will be able to use either K+L, or CAN bus to interface with the car.
    A KKL lead should work.
    Your existing lead could possibly work with the earlier version 311.
  5. Talking Re: diagnostics
    Norwich
    I have tried vag-com 311 it does not work!Sounds like i have bought wrong lead. I will inform you how i get on with other leads thanks
  6. Re: diagnostics
    Canada
    I use a 3rd party ebay lead with v409 works perfectly. Is it a USB or serial lead? post a link to the lead you bought we may be able to determine whats happening
  7. Talking Re: diagnostics
    Norwich
    It is a usb lead item no 300155470458 if you enter it in search box e bay
  8. Re: diagnostics
    Canada
    That lead will work Audi don't use can-bus until 2005.
    You need to use Vag-com V 409.
    I suspect what has happen is you've plugged the usb lead in but not check to see which serial port has been assign to it. It need to be com 1, ,2 ,3 or 4.
    You can change this within device manager in the ports section.
    I will go into more detail if this is confusing.
  9. Talking Re: diagnostics
    Norwich
    Yes it came up as com 3 i saved it in options and it keeps searching and says cannot find modules and interface although it says com port working correctly . even more confusing!
  10. Re: diagnostics
    Canada
    Ok, do you have the ignition on?
  1. Vag Com or any other Diagnostics
    By Muddy19 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-08-2008, 11:29 PM
  2. Audi Diagnostics
    By abbeyhouse in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-10-2007, 04:03 PM
  3. Climatronic Diagnostics
    By milenia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2007, 10:17 AM
  4. Passat Diagnostics
    By derekdublin in forum Passat - Archive Topics
    Last Post: 13-02-2007, 12:25 AM
  5. Which VAG COM Cable To Purchase For Diagnostics?
    By Studio54 in forum Passat - Archive Topics
    Last Post: 12-10-2006, 06:17 PM
