Thread: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
Results 1 to 9 of 9
  1. HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Oct 2015
    Durban, ZA
    Hi all
    I am having a problem with a generic HID kit that one light keeps working on and off. I have replaced ballast, tube and even swapped the entire fitting. The channel still works inermittently. I used warning cancellors (2 of them in series) to no avail. So i decided to bypass everything with a relay. The relay coil energizes in place of the lamps, but there is hectic chatter on the relay. Also, voltage at light is 11V, and battery is 12.8V.
    How do i disable the frequency on the lights?
    Sent from my SM-N900 using Tapatalk
  2. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Dec 2013
    From - Walney Island, Cumbria, Live in: Larkhill, Wiltshire
    11 Post(s)
    Yo,
    Easy fix, reinstall original and ditch kit. Sorry if it's not the answer you were looking for but I have a bad standing with HiD kits. I've only heard of about 2 people which spent the extra £3-400 on the correct HiD projectors to go with them. I've also heard many times that 90% of HiD kits are junk, hence the fact they cost a fortune as an optional extra
    Just my two cents
    Good set of original Osram Nightbreakers or Phillips white vision works wonders.
    Mini
    2 2 0
  3. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Oct 2015
    Durban, ZA
    Mini. Thank you kindly for the reply! I reckon you are right. I will revert, and maybe get factory HiD lights!!
  4. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Oct 2015
    Durban, ZA
    I also replaced incandescent globes with LED type globes. Now i have a warning light for globes. Which ones work best?
  5. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Dec 2010
    Worcs, UK
    Halogen bulbs.... LEDs will cause cold test to fail and turn the warning light in dash on.
  6. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Oct 2015
    Durban, ZA
    I have some CAN-Bus LED globes and VAGCom tells me those that are replaced, are no longer in error. I just can't find bayonet bulbs that are correct
  7. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Dec 2010
    Worcs, UK
    Probably because halogen headlights are not made for LEDs or HID kits.
    Not sure why people keep on using LEDs and HIDs when they are illegal in halogen headlights.
    0 2 0
  8. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Feb 2013
    Gloucester
    57 Post(s)
    Quote Originally Posted by itavaltalainen View Post
    Because they can see better but don't care they are blinding everyone else.
  9. Re: HID kit on 2012 1.2TDi Polo Bluemotion intermittent
    Dec 2010
    Worcs, UK
    If people would at least see better with them.... can't really see a point in them, loads of glare, lacks the definition (bright/dark field) of real xenon light with proper projectors.
  1. HID kit for mk3 polo?
    By Michaela in forum Polo - Derby - Lupo - Fox
    Last Post: 09-11-2014, 12:38 AM
  2. Replacement wing mirror cover - 2012 bluemotion
    By Johntheboy in forum Polo - Derby - Lupo - Fox
    Last Post: 06-04-2014, 11:05 PM
  3. 2012 (62 plate) Passat Intermittent Braking Issue
    By w0067814 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 24-09-2013, 12:17 PM
  4. Aftermarket HID Kit for Polo 9N? Can-bus?
    By shaiboy_uk in forum Polo - Derby - Lupo - Fox
    Last Post: 05-11-2012, 12:27 AM
  5. TT Intermittent HID Headlight
    By serpent887 in forum TT - 8N Forum - 1998 - 2006
    Last Post: 11-11-2011, 06:13 PM
