Thread: Limp Home Mode
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
  1. Limp Home Mode
    Apr 2010
    uk
    OK so it needs a session on the fault code reader to find out what the problem is but I just wonder what the culprit could be, my car is a diesel and it occasionally goes to limp home accompanied by the heater coil warning light when under full load, restarts ok with no warning light and runs normally until I need full power which could be the same day or a few days later, just depends on my driving style as I can drive all day and no limp home event.
  2. Re: Limp Home Mode
    Pembrokeshire
    22 Post(s)
    the usuall culprit is a clogged vnt mechanism within the turbo. either remove and strip the turbo in order to clean it or fit a new one. there are products you spray into the turbo to remove the built up carbon but these are usually only a temporary solution. a good italian test drive can also help, gets them hot and moving. being a taxi i would imagine you drive for economy..
  3. Re: Limp Home Mode
    134 Post(s)
    2010 Post(s)
    Which engine type code, BKP?
  4. Re: Limp Home Mode
    Apr 2010
    uk
    Engine code is CBD if I have deciphered it correctly, yeah, I suppose lack of regular high speed thrashing won't help as I am on autopilot around town mostly returning an average of 40mpg. It's going for a session on the code reader later in the week when he gets his laptop back.
  5. Re: Limp Home Mode
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by taxi3528 View Post
    Engine will be a CBDA, CBDB or CBDC common rail as all 'C' engine codes are 4 letters. I'm guessing yours is MY2009 / 2010??
    I believe these have a DPF which is not good for town driving either. Needs a good run once a week with a decent amount of right foot!
  6. Re: Limp Home Mode
    134 Post(s)
    2010 Post(s)
    I would expect a fault code read to show an underboost problem and this is nearly always due to a failed turbo actuator. There is a repair kit for this from VW (most TPS depots keep three on the shelf) and these costs £146.18. If you do get this code, remove the rubber pipe to the actuator from its connection at the valve and suck on it, you should not be able to draw air through. The catch is that to fit it is very fiddly and it must be set up on the computer display so its output voltages can be observed. We have had to set quite a few up for other garages.
    1 2 0
  7. Re: Limp Home Mode
    Apr 2010
    uk
    It was plugged in this morning and yes indeed it was the turbo boost actuator, seemingly there is a diaphragm inside which goes goes but I will be entrusting the work to someone else as I have lost interest in diy repairs since engines were fitted east and west. Long live the Rover v8 engines.
    0 2 0
  8. Re: Limp Home Mode
    134 Post(s)
    2010 Post(s)
    Bring back push rods, rocker arms, points and carbs!
    0 3 0
  9. Re: Limp Home Mode
    Jan 2012
    10 Post(s)
    88 Post(s)
    But not crank handles!!
    Mad Mitch
    0 3 0
  10. Re: Limp Home Mode
    Apr 2007
    France
    12 Post(s)
    I'll second that. I can dismantle my MG into its component parts with a set of AF spanners and a couple of other tools I've got in my garage.
    Then again, I suppose it only needs a small plastic card to do the same with a Passat.
    1996 Laguna 2.2D
    1977 MGB roadster
    0 3 0
  1. Limp home mode
    By samcaravelle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-08-2009, 10:53 AM
  2. Please Help A4 Auto in limp home mode :(
    By BrokenoldAudi in forum Chat - Anything with wheels
    Last Post: 18-11-2008, 11:54 PM
  3. limp home mode
    By fyneart.com in forum Chat - Anything with wheels
    Last Post: 31-05-2008, 10:27 AM
  4. Tiptronic Limp Home Mode
    By ddreeves in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2008, 07:31 PM
  5. limp home mode
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-01-2008, 02:55 PM
