Thread: Have had a scan done anyone any ideas?
Results 1 to 10 of 15
  1. Have had a scan done anyone any ideas?
    Aug 2015
    Belfast
    Having trouble starting and rough running of engine, have had a scan done, i can discoonect the CTS and it runs fine any ideas?
    Code:
    Saturday,26,September,2015,15:13:57:21953
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    Ross-Tech: Home
    VIN: WVWZZZ3CZ6E085614   License Plate: ULZ 7646
    Mileage: 181520km-112791mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 53 56 5D 62 72 77
              7D
    VIN: WVWZZZ3CZ6E085614   Mileage: 181520km-112791miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5D-Operations -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 906 018     HW: 03G 906 018
       Component: R4 2.0l PPD1.1 G    9722
       Revision: --H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 66565 257 00002
       VCID: 62CDCD6EBD1A702E2B-8036
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658085400
       Coding: 0013602
       Shop #: WSC 05311 000 00002
       VCID: 2F6B745ABE488D46F4-807A
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 DF
       Component: Climatic PQ35   090 0505
       Shop #: WSC 00000 000 00000
       VCID: 6BD3A04A4AD0316698-803E
    1 Fault Found:
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000002101342
       Coding: 00800F0700041000000A00000F00000000085D435C0000
       Shop #: WSC 05311 000 00000
       VCID: 30697726A37692BEED-8064
       Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00065493
       Shop #: WSC 05311
    Address 15: Airbags        Labels: 3C0-909-605.lbl
       Part No SW: 3C0 909 605 F    HW: 3C0 909 605 F
       Component: 02 AIRBAG VW8   029 2421
       Revision: 08029000    Serial number: 0039USG1RFFF
       Coding: 0012338
       VCID: 295F9A4280ACE3762A-807C
       Subsystem 1 - Serial number: 6332MSME0B281229
       Subsystem 2 - Serial number: 6342MSME0A7A0E20
       Subsystem 3 - Serial number: 6351HTS6L4IO5796
       Subsystem 4 - Serial number: 6361HTS65CHMP5Q2
       Subsystem 5 - Serial number: 6371VTS68SDQ2AP2
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
       Component: Lenksäulenmodul 007 0010
       Revision: 00007000    Serial number: 3C9953507C
       Coding: 0001012
       VCID: 2A5D654E85AAE86E23-807E
    1 Fault Found:
    00002 - Transmission Control Unit
                004 - No Signal/Communication
    Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
       Part No SW: 3C0 920 970 G    HW: 3C0 920 970 G
       Component: KOMBIINSTRUMENT VD1 3938
       Revision: X0032000    Serial number: 00000000000000
       Coding: 0000007
       Shop #: WSC 00999 444 64523
       VCID: 28599F469BA6DA7E35-807C
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
       Component: Gateway         007 0040
       Revision: 00007000    Serial number: 0700C058260345
       Coding: 3DFD2C14E61003
       Shop #: WSC 33370 123 1048576
       VCID: 214F8262F89C2B3672-8074
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
                000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 201
                        Mileage: 181523 km
                        Time Indication: 0
                        Date: 2015.09.22
                        Time: 15:09:56
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 K    HW: 3C0 959 433 K
       Component:    IMMO         038 0367
       Revision: 00038000    Serial number: VWZCZ000000000
       Shop #: WSC 33370 000 1048576
       VCID: 326D7D2EAD7AA0AE9B-8066
       Subsystem 1 - Part No: 3C0 905 861 J
       Component:    ELV          029 0380
       3C0905861J     ELV          029 0380
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
       Part No: 1K0 959 701 K
       Component: Tuer-SG         024 2360
       Coding: 0000693
       VCID: 3665413E4112BC8EB7-8062
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K2 909 144 J
       Component: EPS_ZFLS Kl.4   D04 1606
       VCID: 3363782A5260A9A690-8066
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 038 0455
       Coding: 19910A0801860E7638049F1F70085FCE503C00
       Shop #: WSC 00046 412 81920
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 3C0 951 171 A
       Component: Neigungssensor  002 0508
       Subsystem 3 - Part No: 3C0 951 171 A
       Component: Innenraumueberw.002 0508
    Address 47: Sound System        Labels: 3C0-035-456.lbl
       Part No: 3C0 035 456
       Component: 08K Audioverst.     0003
       Revision: 00001000    Serial number: 00000000002373
       VCID: 5DB7FE9284644FD616-8008
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
       Part No: 1K0 959 702 K
       Component: Tuer-SG         024 2366
       Coding: 0000692
       VCID: 377B4C3A46184586AC-8062
    Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
       Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
       Component: EPB  VC8HC001   013 0001
       Revision:   013
       Coding: 0000012
    1 Fault Found:
    02844 - Lamp for Automatic Parking Function
                009 - Open or Short to Ground - MIL ON
                 Freeze Frame:
                        Fault Status: 11101001
                        Fault Priority: 4
                        Fault Frequency: 86
                        Reset counter: 160
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 10.35 V
                        Count: 64
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 56D 035 190 A    HW: 56D 035 190 A
       Component: RCD510USBRVC  002 0003
       Revision: -----001    Serial number: VWZ4Z3P8199732
       Coding: 0100046404000B
       Shop #: WSC 00078 790 00170
       VCID: 224D8D6E3D9A302E6B-8076
    Address 5D: Operations        Labels: 3C0-035-151.lbl
       Part No SW: 3C0 035 151 B    HW: 3C0 035 151 B
       Component: J738            009 0018
       Revision: 00009000
       Shop #: WSC 98765 666 38177
       VCID: 173BACBA26D865868C-8042
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
       Part No: 1K0 959 703 F
       Component: Tuer-SG         021 2432
       Coding: 0000144
    1 Fault Found:
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
       Part No: 1K0 959 704 F
       Coding: 0000144
       VCID: 34617B36576EAE9E89-8060
    1 Fault Found:
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    Address 77: Telephone        Labels: 3C0-035-730.lbl
       Part No SW: 3C0 035 730     HW: 3C0 035 730
       Component: Telefon             2809
       Revision: 00008000    Serial number: 0000000000056
       Coding: 0020055
       VCID: 58B9EF86EB46AAFE45-800C
    2 Faults Found:
    00446 - Function Limitation due to Under-Voltage
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 161
                        Mileage: 181523 km
                        Time Indication: 0
                        Date: 2015.09.22
                        Time: 15:12:15
    00003 - Control Module
                014 - Defective
                 Freeze Frame:
                        Fault Status: 01101110
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 161
                        Mileage: 181523 km
                        Time Indication: 0
                        Date: 2015.09.22
                        Time: 15:09:50
    Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
       Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
       Component: PTC-Element         0404
       Revision: 00800000    Serial number:
       VCID: 2D576E52B444FF56C6-8078
    End-------------------------(Elapsed Time: 01:55)--------------------------
    Sent from my SM-T805 using Tapatalk
  2. Re: Hve had a scan done anyone any ideas?
    Oct 2005
    Rough idling is the sign of a faulty CTS.
    You have a lot of fault codes, have you cleared them, driven around and then rescanned? If not, please do that and post the newest results.
    If you have, the faults are as follows;
    00229 - 00229 - Ross-Tech Wiki
    00002 -
    01044 - 01044 - Ross-Tech Wiki
    02844 - 02844 - Ross-Tech Wiki
    01813 - 01813 - Ross-Tech Wiki
    01814 - 01814 - Ross-Tech Wiki
    00446 - 00446 - Ross-Tech Wiki
    00003 - 00003 - Ross-Tech Wiki
    I suspect you've either attempted to fit/code something and it's gone wrong, or your battery has recently failed.
  3. Re: Have had a scan done anyone any ideas?
    Aug 2015
    Belfast
    Yea mate there is a eBay special radio in it from when I bought it,
    Not really bothered about that at the minute more so trying to get it to run right lol
    I should have mentioned in my post I have already replaced the CTS with one from TPS and has made no difference unless it's disconnected
    Sent from my Nexus 5 using Tapatalk
  4. Re: Have had a scan done anyone any ideas?
    Oct 2005
    Quote Originally Posted by Sam View Post
    And this part?
    There are no CTS fault codes there, despite you starting it without it being connected.
    I suspect you need a new battery, but I am not a mechanic. If you can test with a new battery, please try.
  5. Re: Have had a scan done anyone any ideas?
    Aug 2015
    Belfast
    Previously with a snap on solous computer I have I was getting
    Coolant temp sender signal too high
    That's why I replaced the sensor
    The fault code had been cleared as I reconnected the sensor after starting, that's why It not on the scan we did
  6. Re: Have had a scan done anyone any ideas?
    Oct 2005
    You scanned, found a CTS fault code, replaced the CTS, cleared the code, drove the car around a bit, rescanned and the results are what we see above - correct?
  7. Re: Have had a scan done anyone any ideas?
    Aug 2015
    Belfast
    Yes that's correct sorry should have been a bit clearer
  8. Re: Have had a scan done anyone any ideas?
    Aug 2015
    Belfast
    This is a sceen shot of vcds from the internet for example purposes
    My air flow reading read
    (Specified ) 1242
    (Actual) 456
    The specified amount does not change at all
    Do these measurements see a little off?
  9. Re: Have had a scan done anyone any ideas?
    Oct 2005
    My money's on the battery still.
  10. Re: Have had a scan done anyone any ideas?
    Aug 2015
    Belfast
    Changed the battery this morning and still no difference anyone any other suggestions? Some one is bound to have had this issue before?
  1. Please Help 9N no start due to communication errors, please see scan log, any ideas?
    By jocker01 in forum VCDS - Help Requests
    Last Post: 17-11-2014, 05:01 PM
  2. Fault found on scan, any ideas?
    By Dieseldoos in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-10-2013, 07:52 PM
  3. any ideas on below scan
    By maccayzf in forum VCDS - Help Requests
    Last Post: 08-10-2013, 08:48 AM
  4. Scan help
    By Donut_steve in forum VCDS - Users Locations
    Last Post: 02-04-2009, 06:54 PM
  5. OBD scan tool will not scan 98 jetta 2.0 (bora uk)
    By Romb4557 in forum Bora - 1998 - 2005
    Last Post: 17-01-2007, 05:29 AM
