Thread: Passat B6 nothing signal to the dashboard not start
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Passat B6 nothing signal to the dashboard not start
    Sep 2008
    SE London
    Quote Originally Posted by martin1810 View Post
    ESCL has failed. No electrics will work while ESCL is in lock position. Move ESCL to unlock position and ignition will come back but engine will not start.
    ESCL = Electronic Steering Column Lock.
    As detailed in my .doc
  2. Re: Passat B6 nothing signal to the dashboard not start
    Feb 2007
    When mine failed, I stripped the column out and removed the module.
    The fault was that the microswitches went to high resistance with the button in the position it rests in with the ignition on.
    This was entirely caused by a build up of dirt / grime on the contacts.
    Reading were something like this.
    Fully open - infinite resistance
    Fully closed - 0 ohms.
    Normal position - 20 ohms.
    I cleaned everything with contact cleaner and got it to 0 ohms at normal position for ignition on.
    Reassembled, and it's been perfect ever since.
    A few hours time, no money spent.
  1. Replies: 19
    Last Post: 13-01-2015, 09:15 PM
  2. Replies: 0
    Last Post: 17-11-2014, 04:33 PM
  3. Dashboard lights flashing on ignition, disappear on engine start
    By Steve- in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-05-2012, 12:38 PM
  4. 04 Passat Dashboard Indicator Lights
    By westerboyz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-01-2008, 11:30 PM
  5. 04 Passat Dashboard Indicator Lights
    By westerboyz in forum Passat - Archive Topics
    Last Post: 26-01-2008, 10:22 PM
