Thread: Ecu pinout anyone?
Results 1 to 10 of 18
  1. Ecu pinout anyone?
    Aug 2015
    Belfast
    Has anyone go an ECU pinout diagram for the BKP 2.0tdi,
    Getting coolant temp sender signal too high
    (Another thread relating to the symptoms and issues is floating about)
    Looking the pinout to do wiring tests to and from the ECU
    Checking for shorts, continuity , etc.
    Or even if you know which pins are for the coolant temp that would do too
    Sent from my Nexus 5 using Tapatalk
  2. Re: Ecu pinout anyone?
    glasgow
    35 Post(s)
    It maybe easier just to replace the temp sensor ?
  3. Re: Ecu pinout anyone?
    Aug 2015
    Belfast
    Replaced it an all mate unfortunately no luck
  4. Re: Ecu pinout anyone?
    SE London
    Erwin would be my best source
  5. Re: Ecu pinout anyone?
    Aug 2015
    Belfast
    Who's erwin
  6. Re: Ecu pinout anyone?
    glasgow
    35 Post(s)
    Whats the volts at the temp sender ?
  7. Re: Ecu pinout anyone?
    Aug 2015
    Belfast
    5v at the signal wire,
    All else failed I was going to hardwire to the ECU to rule out possible wiring fault
  8. Re: Ecu pinout anyone?
    glasgow
    35 Post(s)
    have you tried it with the engine off, but the ignition on ?
    is the coolant clean ? no sign of rust ?
    Are the fans running when they shouldn't be ? low fan & high ? Are they running continuously ?
  9. Re: Ecu pinout anyone?
    Aug 2015
    Belfast
    Yip 5v from the signal wire and ground on the other
    Coolant seems ok
    And fans appear to work as should
    The main issue I'm having is hard to start and runs rough, but disconnect the CTS and starts on the button and runs like a dream (just black smoke)
    Connect the sensor back in returns to hard to start and running rough
  10. Re: Ecu pinout anyone?
    glasgow
    35 Post(s)
    Have you got a fault reader like the autel vag505 to check the coolant temp in live data ?
    I know its a new sensor, have you exchanged it for another one ? It could be the new sensor is faulty
  1. Please Help Concert II+ pinout explained
    By WULL1E in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-01-2013, 01:44 PM
  2. 2.5TDi Diesel ECU repaired - still showing ECU fault
    By wanstronian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-09-2012, 05:32 PM
  3. Audi A4 B6 ecu pinout for MAF
    By datam in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-03-2011, 06:14 PM
  4. Pinout on MMI console around gearlever
    By Cavokk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-03-2010, 02:51 PM
  5. Witing harness pinout
    By qdog112 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2008, 04:41 PM
