Thread: Engine fluctuating revs, shuddering car
  1. Engine fluctuating revs, shuddering car
    Jun 2012
    Aberdeen Scotland
    2010 A6 3.0TDI engine CDYA tiptronic le mans edition
    Can someone look at this video and tell me why the engine is doing this.
    Usually happens when engine is neither 90°c or cold, usually around 75°c.
    https://www.youtube.com/watch?v=04ef3xl9E_s
    Garry.
    VW golf GTi 1991 8 valve 3 door
    Alfa Romeo Giulia 2021 2.0 Turbo petrol
    Gone 2010 A6 Quattro Le Mans S Line 3.0TDi - Remapped to 290BHP by e-maps.co.uk, money well spent
  2. Re: Engine fluctuating revs, shuddering car
    Jul 2015
    Staffs
    46 Post(s)
    Did it do it before the remap?
    You need to do a scan. Could be throttle body. I read about a similar issue which improved after the guy changed the glow plugs......... http://www.pistonheads.com/gassing/t...g%20revs&mid=0
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Engine fluctuating revs, shuddering car
    Jun 2012
    Aberdeen Scotland
    Thanks Rowdy,
    only had the car a few weeks when I remapped it. The car has been scanned and no faults. I do have my own OBD-2 bluetooth dongle, will plug it in when car does this next time.
    Thought glow plugs were only needed to fire up the cold engine?
    Garry.
  4. Re: Engine fluctuating revs, shuddering car
    May 2014
    Darlington
    78 Post(s)
    Glow plugs are only used to start the car when the engine is cold after that they are switched off, and they not used again until the next cold start. They are not like spark plugs which are in constant use when the engine is running.
    I would be looking at MAF, EGR, or one of the sensors, but before you start swapping out bits it's best to get vcds and run logging on the engine ECU while the car is doing that, you should be able to see spikes in the logs which could point you in the right direction. I remember my old A4 1.8 was doing a similar trick and it turned out to be the MAF.
  5. Re: Engine fluctuating revs, shuddering car
    Aug 2009
    London
    From previous experience with my 2.0tdi a6 it was the EGR that was at fault. Try disconnecting the maf sensor and take it for a ride. When you disconnect the MAF the car runs at optimum values. Burns a little more fuel but at least it's a easy free test. I ended up blanking mine.
    Sent from my Elephone P8000 using Tapatalk
  6. Re: Engine fluctuating revs, shuddering car
    Jul 2015
    Staffs
    46 Post(s)
    I was only going by what the guy in thread said, but i think 'gupsterg' made a long thread on this forum. It didn't fix his problem after further reading.
    Ian
  1. Golf Mk5 2.0 FSI - Fluctuating/High Engine Load when car is just idling
    By garymansell in forum VCDS - General Questions
    Last Post: 13-09-2014, 01:02 AM
  2. Golf Mk5 2.0 FSI - Fluctuating/High Engine Load when car is just idling
    By garymansell in forum Golf MK5 - 2004 - 2009
    Last Post: 11-08-2014, 02:28 PM
  3. Engine shuddering at idle and low revs
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-01-2011, 07:15 PM
  4. Question Engine Revs Fluctuating?????
    By Fattrucker in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 05-01-2011, 10:21 PM
  5. Fluctuating Revs on a 52 Lupo
    By Tomangela in forum Polo - Derby - Lupo - Fox
    Last Post: 10-08-2007, 09:15 PM
