Thread: A6 2.0 TDI - 255/35R19 - type pressures?
  1. A6 2.0 TDI - 255/35R19 - type pressures?
    May 2011
    Ireland
    Hey folks,
    Couldn't find an answer after a forum search, so with a risk of someone telling me it has been asked before..here it goes!
    I have an A6 2.0 TDI now fitted 255/35R19 (and lowered suspension to match). Under the fuel cap it doesn't mention anything about R19s anyone have an idea what tyre pressure I should be running in the front/back?
    Phily
    2012 Audi A8 Mods; Heated steering wheel,
    2012 Skoda Superb II Mods; OEM toebar retrofit, auto dimming headlights, VAG rear parking camera
  2. Re: A6 2.0 TDI - 255/35R19 - type pressures?
    Jul 2007
    glasgow
    35 Post(s)
    rough guess at 30 psi to get you home ? Usually tyres are 29 to 32 psi depending on load
  3. Re: A6 2.0 TDI - 255/35R19 - type pressures?
    May 2011
    Ireland
    So, I ended up Googling/Yahooing/Binging and found this; Tyre Pressures for BMW, Mercedes, VW Audi, Porsche and more | Alloy Wheels Direct
    Seems like Front/Rear should be
    2.5/2.2bar light loading (36/32psi)
    2.7/3.1bar full loading (39/45psi)
    Yea learn something new each day hopefully, that helps someone in the future
  4. Re: A6 2.0 TDI - 255/35R19 - type pressures?
    Jul 2007
    glasgow
    35 Post(s)
    The front are really hard, but I have never had such low tyres as this size
  5. Re: A6 2.0 TDI - 255/35R19 - type pressures?
    May 2011
    Ireland
    Quote Originally Posted by niall campbell View Post
    Yea, this could have accounted for the road noise during a trip Dublin<->Galway - must do more motorway miles to test
  6. Re: A6 2.0 TDI - 255/35R19 - type pressures?
    Jul 2007
    glasgow
    35 Post(s)
    Well that could be due to the tyre itself, if the rubber is harder then yes you will get more miles out of the tyre before replacing, but the trade off is its more noisier
    New tyres will have Noise ratings of say 70db, fuel economy rating & also grip in the wet.
    For example some of the cheaper tyres have good ratings across all 3 of noise, fuel and grip ............... but will they return the mileage before replacing ?
    With the lower profile tyres, you may find the tyres have to be harder so if you hit a pot hole , it doesn't hit the rims & the tyre walls are harder for better handling at speed. That means more tyre pressure
  1. 255/35/19 tyre pressures
    By gman11 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 28-07-2015, 10:56 AM
  2. Anyone recommend Audi A4 2L TDI S line Estate Tyres 255 55 R19's ? Thanks
    By evanwilkin in forum Chat - Anything with wheels
    Last Post: 25-01-2015, 05:37 PM
  3. Question What tyre pressure for 255/40/19 on 3.0 TDI?
    By ChrisCi in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 17-08-2014, 03:06 PM
  4. Anyone Used / Using VREDESTEIN ULTRAC SESSANTA - 255/35R19?
    By Bristle Hound in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-07-2011, 07:43 PM
  5. 255/40 R19s on A6 55 reg SE, 2.0 tdi
    By nemerkh in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-12-2009, 08:08 PM
