Thread: Swirl flap repair kit
  1. Swirl flap repair kit
    Dec 2013
    Liverpool
    10 Post(s)
    Anyone used one of these?
    Looks like I need to do bank 2, is that the driver or passenger side, how easy is it to do and is there any where in particular I should buy the kit from and how much is the kit?????
    2007 2.7 SE quattro saloon
  2. Re: Swirl flap repair kit
    46 Post(s)
    There is a guide on this forum showing all information needed and even I think includes on how to fit it. Do a search.
  3. Re: Swirl flap repair kit
    Nov 2012
    Somerset UK
    Bank 2 is the passenger side on a UK RHD car which is the easiest side to do and will take maybe 20 mins in total.
    Bank 1 is slightly harder but possible and will take twice as long and a lot more swearing.
    I've fitted both the swirl flap arm repair kits and the faults returned after 2k miles as the inlet manifold needs to come off to be cleaned and new internals.
    I did a write up but can't find it...in fact it's very hard to find 'how to' guides not in the 'how to' section
  4. Re: Swirl flap repair kit
    Aug 2012
    Aberdeenshire
    There two kits.
    The Audi one is just the pushrods and cost about £25 IIRC.
    Not really worth it as the links are worn - but not as much as the flap spindle bearings!
    Airshox (I believe they are a sponsor on here) Home - AirShox do a range of full repair kits, varying in price depending on what you need.
    Get the Airshox kit that has at least the rods, bearings and flaps. Make sure you take note of the way it goes together.
    Check the motors are working be watching them move on start-up.
    Also beware there can be wiring issues causing this fault too.
    VCDS can test the motors, and I believe adapt them (Google will find it) if needed.
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon SOLD
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue SOLD
    2006 A6 Allroad 3.0 TDi, Blue - getting ready to get rid of
    2008 A5 3.0 Tdi Quattro Coupe, Grey
    2010 A6 Allroad 3.0 TDi, Blue
  5. Re: Swirl flap repair kit
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by peter goble View Post
    Bank 2 is passenger side, swirl flap motors = red boxes, ignore rest of markings as this was used for something else as well .
    As stated by Mark can be done without removing other bits but here is a video showing swirl flap motor removal and arm fitting.
  6. Re: Swirl flap repair kit
    Dec 2013
    Liverpool
    10 Post(s)
    Now not sure what to do. I have just found a complete re-manufactured unit on EBAY from Germany for £170.00, sold 182, only 14 left. any thoughts on this??
  7. Re: Swirl flap repair kit
    Nov 2012
    Somerset UK
    Am unsure at the reason for your confusion, did you follow the link for Airshocks that Paul posted?
    As he states they're a forum sponsor and I think their price works out a few £'s cheaper than the £170 you've seen on Ebay...although you didn't post the link!
  1. Audi V6 TDi 2.7 & 3.0 Inlet Manifold, Swirl Flap Repair Kit.
    By tonyandkaty in forum 3.0TDi - Engine
    Last Post: 03-10-2015, 05:21 AM
  2. Swirl Flap question
    By dan2485 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-10-2014, 08:19 PM
  3. 3.0 and 2.7 Swirl Flap Repair Kits
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-10-2013, 05:45 PM
  4. Please Help 3.0 V6 TDi Swirl Flap Repair Kit
    By bigman1 in forum Touareg
    Last Post: 15-07-2013, 05:09 PM
  5. swirl flap repair set
    By urgi in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 08-04-2013, 10:23 PM
