Thread: windscreen blower broken
  1. windscreen blower broken
    Aug 2015
    Hi again guys. Just before I left for the airpot for my holiday the little stepper motors for the flaps that direct the heater blower air sounded like they were having a wee dance to themselves. Since then I cant get any air directed to the windscreen, so that whenever it rains (evey day being scotland) the windscreen immediately fogs up. Would it be possible that one of you fine gents/ladies has a photo showing which of the motors controls the flap for the windscreen so I can wedge it open until I can get a replacement. There are a couple of B6's in my local scrappy, one of which has the dash conveniently missing so the whole unit is easily accessible. I couldnt really tell which was which though. If the unit is the same as the B5 I can get one from a neighbour that has broken one.
    cheers, Gill
  2. Re: windscreen blower broken
    Aug 2015
    North Lanarkshire
    Can you not check the one in the scrappy and physically move the flaps to find out which is which?
    2005 A4 1.9TDI Avant Sport ~ 1997 mk3 Golf GTI 8v (Currently in bits)
  3. Re: windscreen blower broken
    Aug 2015
    I did have a play with it at the time but without air blowing through I couldnt tell what each flap was actually doing. If it is the same as the B5 one I should be able to check with my neighbours one more easily as his is completely stripped out - more so than the one at the scrappy.
  4. Re: windscreen blower broken
    Aug 2015
    turns out it was dead simple. just remove the glove box, its the stepper motor attatched to a long green linkage. it was just jammed up. gave it ba little tug and now alls well again. while i was in the car i swapped the knackered cloudy auto dimming rear view with the replacement i took out of an a6 while i was at the scrappy. it doesnt appear to work but i can at least see out of it. oddly it has yellow glass. i tested it by switching on the lights and covering the sensor on the windscreen side and shinig a torch on the sensor on the mirror side.
    gill
  5. Re: windscreen blower broken
    Dec 2009
    southampton uk
    You might find the motor sticks again cos the first time is a warning that the lube inside is failing.I had to take mine out and clean up and that's best done in kind weather not left to mid winter.There are guides on how to
    1 1 0
  6. Re: windscreen blower broken
    Aug 2015
    I'm going to get a pile of the steppers as it seems like a pretty common fault. At least the job is straightforward, only took about ten minutes or so. I agree though, its only going to fail in cold wet weather when you really need the windscreen demist.
  7. Re: windscreen blower broken
    Dec 2009
    southampton uk
    It may be worth overhauling any replacement cos its a common fault for the lube to harden and cause jamming
  1. Please help : A3 1.9 TDI windscreen mists up when I put on demist blower
    By madanglian in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-06-2014, 03:32 PM
  2. Please Help A4 2.5 TDI Quattro Sport - Windscreen blower vent not working - Need new servo
    By mjsork in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2013, 06:22 PM
  3. Blower problems on windscreen.
    By pgtips2009 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2009, 12:49 AM
  4. Please Help Broken Blower = Steamy windows
    By craigm00r in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-01-2009, 09:28 AM
  5. Windscreen defrost blower speed
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-02-2008, 11:15 AM
