Thread: 1.8T AEB (petrol) 1999 - Black engine oil in the air intake hose?
  1. 1.8T AEB (petrol) 1999 - Black engine oil in the air intake hose?
    Jul 2015
    Plymouth England
    Hi, I took the air inlet hose off to find black engine oil in side the throttle body (at the bottom) and in the hose (top and bottom) and also inside the inter-cooler where the hose pushes on to. Could this be a turbo oil seal gone?
    At the highest point is the butterfly valve, surly no oil would come from there, would it?
  2. Re: 1.8T AEB (petrol) 1999 - Black engine oil in the air intake hose?
    Very common. There are no Oil seals in the turbo as such. When the turbo is cold oil leaks from the bearing seals and gets picked up by the boosted air flow and deposited along the length of the pipe work. When hot it still leaks but a lot less as the bearing/seal fit is tighter.
    Regards Peter
  3. Re: 1.8T AEB (petrol) 1999 - Black engine oil in the air intake hose?
    Jul 2015
    Plymouth England
    Thanks for the info
  1. 1999 1.8T AEB (petrol) Checking the low tension & power to injector?
    By anorak_ian in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2015, 10:10 AM
  2. Air Intake Hose noise?
    By canaryfan68 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2014, 12:04 PM
  3. Oil in air intake hose
    By mehlolo1979 in forum Jetta MK3 - 2005 - 2013
    Last Post: 10-12-2012, 02:58 PM
  4. Air intake hose split.
    By Steve Pearman in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-11-2010, 10:26 AM
  5. Passat 2.0l Petrol (130) : Oil in air intake and intermittent misfire
    By zen in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2009, 03:54 PM
