Thread: Fixing loose arm rest
  1. Fixing loose arm rest
    Sep 2015
    Durham, UK
    Just fixed my loose front arm rest. To do this you need two thin hooks, I made these out of cat hangars and a pair of pliers.
    The arm rest is held in place by a bolt which is accessed through the rear air vents. You may need some gloves to prevent hurting your fingers. With a torch you can see in the air vent, either side is a small hole near the bottom. Slide, in turn, a hook and push into the hole. Then you need to pull both, wiggling to remove the vent. It is held in place with metal clips which are very strong! Unclip the connector and remove the vent.
    Next, push out the bin underneath which will give you more space.
    Unclip the vent hose and you should see the bolt at the rear if you remove the vent. Tighten the bolt (think it's 13mm), put everything back together, and done.
  2. Re: Fixing loose arm rest
    Jan 2010
    Yate UK
    17 Post(s)
    Quote Originally Posted by Wrath666 View Post
    I had some of those but the RSPCA took them off me
    Now: 2016 C7 2.0TDi BE with Tech Pack, magic parking, ambient lighting
    Previous: 2013 C7 2.0 TDi S Line
    C6 2.0 TDI LE
    A4 2.0 TDI SE
    and an ancient 80 in the olden days...
    0 3 0
  3. Re: Fixing loose arm rest
    Sep 2015
    Durham, UK
    I tried the dog but he wouldn't sit still
  1. arm rest
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-04-2012, 06:27 AM
  2. Rear Split seats loose at bottom - help fixing??
    By SimAudi in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-09-2011, 11:51 AM
  3. arm rest
    By vwturbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2009, 02:52 PM
  4. Arm rest help
    By steviestdi in forum Bora - 1998 - 2005
    Last Post: 08-07-2009, 09:16 PM
  5. Arm rest
    By BenA4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-05-2007, 10:20 AM
