Thread: I there a stright swap turbo upgrade for 1.9tdi 130 awx engine
  1. I there a stright swap turbo upgrade for 1.9tdi 130 awx engine
    Aug 2015
    Inverness
    Hi looking to start improving bhp/torque in my Audi looking for a stright swap turbo to get things going
  2. Re: I there a stright swap turbo upgrade for 1.9tdi 130 awx engine
    Pembrokeshire
    22 Post(s)
    why, the stock turbo is good for 200 bhp and putting a bigger turbo on won't make it faster unless you get it mapped. a map will see 165 bhp, after which you need injectors, not a turbo. look at 'darkside developments' for ideas.
  3. Re: I there a stright swap turbo upgrade for 1.9tdi 130 awx engine
    Aug 2015
    Inverness
    Just wanting to get bits for it looking for 200horses just the turbo on doesn't seem to be the highest boost pressure runs outa puff quite quick would like more torque after 2500rpm this is my first diesel car so I'm not sure if that is normal
  4. Re: I there a stright swap turbo upgrade for 1.9tdi 130 awx engine
    Pembrokeshire
    22 Post(s)
    yeah, diesels do run out of puff low down, but thats diesels for you. make sure its well serviced, timing belt is spot on etc, injector rockers set right then get it mapped . check out some of the forum sponsors for a good mapper who will also rolling road it as well.
    you need to keep the revs lower and use the torque.
  1. Crunch in second gear, 1.9tdi 130 awx
    By Ganch in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-03-2013, 11:43 AM
  2. VCDS Lite cable experience - Audi A4 B6 (Dec 2001, 1.9tdi 130 AWX)
    By wutr in forum VCDS - General Questions
    Last Post: 12-03-2013, 09:13 PM
  3. Question what controls the vacuum in the turbo system of a 1.9tdi awx?
    By mr_noir_1976 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-03-2013, 01:32 PM
  4. Please Help a4 awx 130 tdi avant: no power..no turbo?
    By TapMyHed in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-07-2011, 09:28 PM
  5. Question egr valve for 2003 1.9tdi 130 awx engine
    By spartan80 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-09-2010, 04:03 PM
