Thread: Rear suspension Help (harsh)
Results 1 to 8 of 8
  1. Rear suspension Help (harsh)
    Aug 2007
    All
    Ive got a 1.8 t 2001 a3 and when I go over small bumps in the road the front make a little bit of a noise as you would expect. But when the back hits the bump it makes double the noise. Its like ive got really stiff suspension at the back or its hitting the limit.... would this be a shock problem? dont think its the tyre pressure. ive got standard rear suspension.
    Any help would be great because ive got know idea because it drives perfectly
    Baker0
  2. Re: Rear suspension Help (harsh)
    Aug 2007
    any ideas?
  3. Re: Rear suspension Help (harsh)
    Jul 2007
    Cheshire, or my A6
    Could well be ruined shocks. Never seen this problem before on an Audi, but there is first time for everything!
    Paul
  4. Re: Rear suspension Help (harsh)
    Mar 2007
    Bedfordshire
    Could it be the parcel shelf making a noise?
    Try removing it and doing it again.
    Current Car: Skoda Octavia vRS Hatch 2.0TDi 170 CR in Candy White
    Outgoing Car: 2007 56 Plate Audi A3 Sport Sportback 2.0TDi 170 PD in Black
  5. Re: Rear suspension Help (harsh)
    If its front wheel drive then the rear beam axle has bonded rubber bushes at its mounting point to the body they could be knackered, their a nightmare to change so unless you've got the facilities i'd let a mechanic do it for you
  6. Re: Rear suspension Help (harsh)
    Aug 2007
    its not the spare wheel or parcel shelf, its alot more harsh than that. ill see if ill get the bushes checked out
  7. Re: Rear suspension Help (harsh)
    Hi, my A3 is the same. Noticed this when I bought it and took it back to garage. They had just got it MOT'd at an independent garage and said the suspension was fine. It only sounds harsh if you go over a ridge or ramp on road which jars suspension, had car 2 years now and no suspension probs, usually only occurs on crap patched up roads round built up area's, no probs on open road. Seem to remember my brothers car was same.
  8. Re: Rear suspension Help (harsh)
    Aug 2007
    My opinion is it's the rear bush. Quite a common thing to go on an older Audi. The rear passenger side was gone on mine, took a couple of hours to replace but the part itself was cheap. Made all the difference in terms of noise
  1. rear suspension
    By bchang in forum Chat - Anything with wheels
    Last Post: 21-08-2007, 01:26 PM
  2. Audi A4 - rattling rear suspension
    By nickkeyser in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2007, 08:28 PM
  3. Golf Mk4 GT TDi rear suspension
    By randall977 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-07-2007, 10:59 AM
  4. rear suspension
    By wednesday13 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-03-2007, 08:46 PM
  5. Rear Suspension bearings
    By Fourbears in forum Vento - 1994 - 1998
    Last Post: 08-02-2007, 01:26 PM
