Thread: Oil leaking from EGR and Intercooler on 1.9 TDI 130
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Oil leaking from EGR and Intercooler on 1.9 TDI 130
    Jan 2009
    Sorry to ask lots of questions, but thanks in advance
    Is this the correct kit for my engine? (Where do I find the correct code for my engine?)
    Darkside 1.9 8v TDI PD105 / PD130 / PD150 EGR Delete / Race Pipe (51mm)
  2. Re: Oil leaking from EGR and Intercooler on 1.9 TDI 130
    May 2012
    Everywhere
    308 Post(s)
    It will be AVF as it's a 130 Sport .
    So 57 mm required .
  3. Re: Oil leaking from EGR and Intercooler on 1.9 TDI 130
    Jan 2009
    Thanks dude
  4. Re: Oil leaking from EGR and Intercooler on 1.9 TDI 130
    Jan 2009
    So I have ordered the EGR delete pipe from Darkside, and then after looking around their site, I saw they also sell gaskets. I emailed to have an intake manifold gasket added to my order, and to advise extra payment, and I receive a new email invoice for both parts, and to my supprise, the gasket was marked FOC!! Fair play to Darkside, that's bloody good of them.
    Now to find out what's the best solution to remove the sooty crap from my intake?
  5. Re: Oil leaking from EGR and Intercooler on 1.9 TDI 130
    Jan 2013
    N/A
    You can try chemicals like brake cleaner or soak in Mr Muscle oven cleaner, or mechanical clean scraping the gunk with a long flat screw driver, wire brush or skewers.
    When I took my turbo, EGR and both manifolds it made a huge mess so make sure you choose your place very carefully. Don't do it in the sink or anywhere indoors...
    And protect your hands by using gloves. You’ll need pretty nasty chemical to loosen those carbons.
    This is pre- post-clean on my EGR (it wasn't as bad as the intake manifold or the turbo):
    Intake manifold was stickier due to slimy oil. I had to use hot water on full flow to flush some out and use screw driver to scrape them off.
    '11 VW B7 Passat Estate 2.0TDi CFFB (Current)
    '98 VW T4 Transporter 2.5TDi ACV (Previous)
    '99 Audi B5 A4 Avant 1.9TDi AFN (Previous)
  1. Low oil warning, EGR valve leaking oil, burning oil smell - please help!
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2012, 01:51 PM
  2. 130 TDI Oil leak from EGR area and heavy breathing
    By speed12 in forum Bora - 1998 - 2005
    Last Post: 05-06-2011, 05:05 PM
  3. Replies: 2
    Last Post: 23-08-2010, 12:45 PM
  4. B5 Intercooler Leaking Oil
    By Mike'A in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-04-2009, 05:15 PM
  5. Oil in Intercooler Ducting and EGR Valve !!!
    By johnnywishbone in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-12-2007, 08:14 PM
