Thread: Hvac retrofit Climatronic - issue
  1. Hvac retrofit Climatronic - issue
    Jul 2013
    oaz
    Hello..
    I'm trying to adapt the climatronic on my A6 2.0 tdi from 2005
    After finding a cheap climatronic, i pulled out my manual one, and connected the new one, and i'm facing this log's on vcds..
    The Climatronic shows OFF on both displays, and also the only 2 functions that are working are the drefosting rear and front window's..
    I know that i have CP, and has to be dealed by an audi shop..
    By the way, i've tried to make "Basic Setting" and it was an error:
    22:55:12 Group 001: Potentiometer && Flap Alignment
    Grundeinstellung durchgefuehrt Error
    12.12 VCDS - LOG
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Control Module Part Number: 4F0 910 043 HW: 4F1 820 043 AB
    Component and/or Version: KLIMABETAETIGUNGH20 0170
    Software Coding: 0000022
    Work Shop Code: WSC 02325 785 00200
    VCID: DBB5F1E71AD0DBC6211-808E
    5 Faults Found:
    02785 - Front Right Upper Body Outlet Position Sensor (G388)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 221859 km
    Time Indication: 0
    Date: 2015.08.23
    Time: 20:30:16
    Freeze Frame:
    Voltage: 11.10 V
    (no units): 40.0
    (no units): 255.0
    00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 221859 km
    Time Indication: 0
    Date: 2015.08.23
    Time: 20:30:16
    Freeze Frame:
    Voltage: 11.10 V
    (no units): 41.0
    (no units): 255.0
    02763 - Potentiometer for Indirect Ventilation Flap Motor (G330)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 221859 km
    Time Indication: 0
    Date: 2015.08.23
    Time: 20:30:16
    Freeze Frame:
    Voltage: 11.10 V
    (no units): 34.0
    (no units): 255.0
    02095 - Component Protection Active
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 221859 km
    Time Indication: 0
    Date: 2015.08.23
    Time: 20:30:16
    Freeze Frame:
    Bin. Bits: 00001111
    01592 - Air Quality Sensor (G238)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 107
    Mileage: 221859 km
    Time Indication: 0
    Date: 2015.08.23
    Time: 20:30:16
    Freeze Frame:
    Temperature: 20.0°C
    Regards
  2. Re: Hvac retrofit Climatronic - issue
    46 Post(s)
    It isn't just as easy swapping the controllers, the whole heating system is completely different.
  3. Re: Hvac retrofit Climatronic - issue
    May 2014
    Darlington
    78 Post(s)
    As chris states, there are a lot of wiring harness changes required and you need to replace the housing that holds the heater matrix & aircon matrix for the comfort version (you will have the basic version fitted) To swap that out you need to remove the center console & dash, you also need to add the missing sensors. Basic to climate is a big installation and not really worth the effort, as your not gaining much.
  1. Please Help RNS-E retrofit display brightness issue
    By lukieno1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-10-2014, 10:12 PM
  2. LED Number Plate Light Unit Issue - Retrofit
    By apole in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-06-2014, 12:08 PM
  3. Question Climatronic Issue
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2011, 11:01 PM
  4. Failed HVAC issue fixed.
    By beanwood in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-08-2011, 09:44 AM
  5. Question is it possible to retrofit climatronic?
    By essayeff in forum Golf MK3 - 1993 - 1999
    Last Post: 22-06-2010, 08:09 PM
