Thread: Q7 3.0 V6 tdi pump belt
  1. Q7 3.0 V6 tdi pump belt
    Dec 2013
    A, A
    Hello, does anyone know what mileage the diesel pump belt should be replaced at, I know the engine is run on chains, is this an easy job to do?
  2. Re: Q7 3.0 V6 tdi pump belt
    Feb 2009
    West Yorkshire
    10 Post(s)
    No spec for this. The belt is cheap £17 ish but about £160 to fit at dealer. I just had mine done when crank pulley failed for piece of mind
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  3. Re: Q7 3.0 V6 tdi pump belt
    Dec 2013
    A, A
    So is there no recommend replacement?
  4. Re: Q7 3.0 V6 tdi pump belt
    Dec 2013
    A, A
    Just spoke to Hitchin audi and they have told me there's no recommendation, how does that work? I checked it on Sunday and it looks ok, but I left the motor trade 15 years ago things change!
  5. Re: Q7 3.0 V6 tdi pump belt
    Jun 2006
    UK, Mids
    It's just a belt, and if it breaks the engine stops. Best just to inspect the condition of the belts every service for signs of contamination, cracking or threads.
    The Previous V6TDI had toothed belts driving a distributor pump and needed timing correctly so it was easier to mark it up and align before replacing rather than wait until it failed, but the modern common rail V6TDI it is just a plain HP pump and you just pop a new belt on and go.
    Audi A8 - 2015 - 3.0TDI
  6. Re: Q7 3.0 V6 tdi pump belt
    Dec 2013
    A, A
    Ok thanks for that, spoke to the parts girl at Hitchin audi who you get more sense out of, and she said in her time working there she's never seen one replaced! So as you say best to just check and inspect.
  7. Re: Q7 3.0 V6 tdi pump belt
    london/ UK
    Quote Originally Posted by h2bnd View Post
    She's not working there long then !
  1. 3.0 TDI V6 Fuel pump belt & tensioner?
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-06-2015, 01:19 AM
  2. fuel pump belt failure - 2.5 tdi
    By samie in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 10-02-2012, 09:14 PM
  3. T4 2.5 tdi pump belt non starter!
    By pinklooney in forum The Commercial Range
    Last Post: 12-08-2011, 08:30 AM
  4. 2.5 TDI Snapped Diesel pump belt!
    By Neil Davies in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 21-06-2011, 12:46 PM
  5. a6 2.0 tdi Timing belt and water pump.
    By sja in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-08-2010, 08:15 PM
