Thread: AUY Engine- Cleaned EGR Valve, Drinks oil, Still flat.
  1. AUY Engine- Cleaned EGR Valve, Drinks oil, Still flat.
    Dec 2006
    Bath
    Hi all,
    I cleaned the EGR Valve and pipes on a AUY 1.9tdi (115).
    The pipe and valve were completely blocked by soot.
    I replaced the vacuum pipes to EGR, Throttle and reservoir.
    I replaced all filters (oil change, oil filter, fuel filter, air filter, cabin filter).
    Still the engine is flat with little pick up between 1,200-2000rpm.
    To add to this after a 30 mile motorway journey I had an oil warning pop up (so I topped up).
    Ideally I wanted to swap out the vacuum pipe for the turbo too but couldn't see it.
    No error codes using "Torque" obdii for android.
    Any advice about what could cause this and a cheap fix?
    Thanks,
    Andy
  2. Re: AUY Engine- Cleaned EGR Valve, Drinks oil, Still flat.
    Dec 2006
    Bath
    Quote Originally Posted by andysuth View Post
    Hi all,
    Thanks,
    Andy
    Ok, I ran it this morning, and I've checked the oil level. It was "high" - but still just on the bend of the dipstick, so I'm not sure if the "Check Oil Level" is a red herring.
    Is it possible I've unclipped the oil switch whilst cleaning the EGR and changing some hoses?
    It's still flat to drive - I'm hoping that's the vacuum actuation tube for the Turbo.
  1. Engine Oil From EGR Valve
    By v1d2m3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-07-2012, 09:14 AM
  2. Oil from EGR valve
    By Inspector Beetle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2012, 10:43 PM
  3. Low oil warning, EGR valve leaking oil, burning oil smell - please help!
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-01-2012, 01:51 PM
  4. Cleaned EGR valve now car is "jumpy" in throttle response
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 09:42 PM
  5. Cleaned out your EGR valve recently? WOW!
    By teccyjim in forum Archive posts
    Last Post: 23-01-2008, 08:37 PM
