Thread: another DPF issue
  1. another DPF issue
    andyam Guest
    Hi guys sorry for posting this as an image but my laptop doesn't connect to the net.
    Anyone help with the fault codes is it the sensor?
    Also how do I force a regen? I don't know if I have cr or pd tdi
    Thanks in advance
  2. another DPF issue
    andyam Guest
    Also this all started yesterday on the way home from work. The day before I took it to Cardiff from Bristol so should be enough of a blast?
    The car DPF came on and the coil pack. Car went limp...no turbo power.
    That night took it for drive up and down the m32. Coil pack went off DPF stayed on gave up went home after 30mjns.
    Next day EML AND COIL Pack and the DPF came on. Limp mode again got to work coil pack off...is this a sensor or a DPF job?
    Tried a forced regen and it failed said not running not running then went stopped for safety
  1. DPF pressure sensor or just a blocked DPF
    By dan2485 in forum VCDS - General Questions
    Last Post: 30-04-2018, 09:24 AM
  2. Replies: 4
    Last Post: 04-09-2016, 11:26 PM
  3. Possible DPF Issue
    By Arragonis in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-03-2014, 08:35 PM
  4. Please Help Dealer talking BS? (DPF related issue)
    By Gregmeister in forum Altea
    Last Post: 08-03-2013, 06:10 PM
  5. Please Help 06 A3 2.0 TDI S Line 170BHP - DPF major Issue...
    By spanglish9978 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-10-2012, 06:17 PM
