Thread: SKC ecu swap
  1. SKC ecu swap
    Aug 2014
    Southampton
    After a very expensive few months of changing the multitronic gearbox to the 6 speed manual, i have just been told by a mobile VAG specialist with vagcom and an Audi workshop that my ecu wont accept the recoding of the ecu from auto to manual so I am now going down thee final route of manual ecu (with matching part numbers) and engine loom. But I will now be needing to recode the immobiliser for the ECU swap and have been told ill need the SKC? how do i obtain that? and do i need the SKC for my original ecu AND the 'new' ecu or just my original?
  2. Re: SKC ecu swap
    london/ UK
    You will need both SKC from both cars. If you get a supervag programer you may retrieve the old pin from the ECU/instrument cluster and the new pin from "new" ECU... Most tools will only read one- immo cluster.
  1. Please Help vw passat 1.8t skc code needed for second hand ecu i just bought helllp i cant drive it
    By greenfumb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-05-2012, 11:08 PM
  2. ECU swap.
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-03-2012, 04:03 PM
  3. Replies: 7
    Last Post: 12-11-2010, 12:56 PM
  4. Ecu swap /repair
    By derekh in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-06-2010, 03:22 PM
  5. Please Help Ecu swap
    By punkfreak in forum Ibiza - Cordoba
    Last Post: 09-04-2010, 09:25 AM
