Thread: Not Much Heat
  1. Not Much Heat
    Oct 2015
    Coventry, UK
    hi all,
    I noticed a couple of days ago that my heater only gets luke warm, even on 'HI' setting.
    Temp is rising as usual (about 5/10 mins till up) and sitting pretty, bang on 90 and not moving.
    My usual guy I use reckons it could be thermostat related, and he's taking a look Thursday,
    just wondered if any of you guys had any ideas.
    cheers
    Mark.
    PS - what is 'ECON' on heater controls, what does it mean/do?
  2. Re: Not Much Heat
    Jan 2016
    Northampton uk
    ECON doesn't use the air con side of the cooling/heating system.
    regarding the Luke warm air from the heater, does it matter where you have the airflow directed?
    im just wondering if one of the direction/ mixing flaps is not operating.
  3. Re: Not Much Heat
    Jun 2007
    Is the feed and return pipes through the bulkhead hot. These feed the heater matrix. Regards Peter
  4. Re: Not Much Heat
    Oct 2015
    Coventry, UK
    hi Mowerman,
    thanks for the reply....
    as for the flaps, I get a good blast from whichever direction I choose (screen, face or floor)
    and whichever is selected, no airflow from others...... and same luke warm temp,
    so I reckon flaps are working just fine.
    its booked in to have matrix cleaned/changed....
  5. Re: Not Much Heat
    Oct 2015
    Coventry, UK
    hi pete,
    thanks for reply,
    I think so, i'm sure the guy who I take it to said so......engine temp right at 90 degrees, but they changed thermostat anyway, but found a lot of muck around it..
    it's booked in to have matrix cleaned/changed, they said it's 100% the problem.
  6. Re: Not Much Heat
    Jun 2007
    Where has the muck come from. I have a 1998 A6 and it has had two coolant changes of G12+ and the coolant is clean. Changing the matrix will empty your wallet. A good back flush through the matrix would be the first port of call. Regards Peter
  1. aux heat over heat
    By kirkyboy in forum Touran - Sharan - Caravelle
    Last Post: 01-04-2010, 07:51 PM
  2. 99 A4 No heat
    By syncyty in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-11-2008, 12:08 PM
  3. no heat
    By sschletter in forum Passat - Archive Topics
    Last Post: 18-01-2008, 10:45 PM
  4. Heat!!!!
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-12-2007, 05:09 PM
  5. No heat
    By marc7 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 19-12-2007, 06:28 PM
