Thread: Rear LED tail light flicker weird!
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. Rear LED tail light flicker weird!
    Begazzz Guest
    Hi all.
    First post and and looks like a common fault but not quite found what I'm looking for ( not a U2 quote)
    car is 2008 2.7 avant Le Mans
    2nd time today I've been flagged by another motorist saying my rear led lights ( not high level or brake lights) flick/flash on ever so quickly.
    Had ad a look tonight with auto lights off and finally saw it. You'll almost miss it if you blink. Sometimes left or right one but not necessarily one after the other sometimes one will do it twice.
    If if it was nackered completely I'd start looking at the earth thing being bad but this seems a bit weird.
    Please can can anyone tell me wher to start. Thanks all in advance.
    Dom.
  2. Re: Rear LED tail light flicker weird!
    Begazzz Guest
    Just be clear the lights are standard led tail lights. Ta.
  3. Re: Rear LED tail light flicker weird!
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by Begazzz View Post
    Hi all.
    LOL , Welcome to VWAF! .
    If in your shoes I'd first remove the tail light units to inspect connections.
  4. Re: Rear LED tail light flicker weird!
    Begazzz Guest
    Yea guess your right. I suppose there are wires going back up to feed the lights in the tailgate as well? But they are doing the same thing so if they are in line then that should be the source. If not I'll smash it to pieces and sell it. I just think it's weird they are both doing it.
  5. Re: Rear LED tail light flicker weird!
    Sep 2011
    Outer tail lights harness goes into body, then control unit.
    Inner tail lights harness goes to hinge, then control unit.
    IIRC .
    Will look at wiring diagram and other stuff tomorrow .
    TBH first thing I'd have done is scanned car with VCDS but as I think you don't have that I skipped that step .
  6. Re: Rear LED tail light flicker weird!
    Nov 2012
    Somerset UK
    Are their any dash warnings of bulb failure?
    Annoyingly was in Heavitree (Exeter) yesterday and had my laptop and VCDS with me.
    If you ever drive up as far as Weston then let me know and I'll do a scan for you?
  7. Re: Rear LED tail light flicker weird!
    Begazzz Guest
    Quote Originally Posted by MarkTM View Post
    Thanks for that appreciate the offer. May well do as its dying for a run anyway. There are no warning lights showing at the moment either.
  8. Re: Rear LED tail light flicker weird!
    Begazzz Guest
    Hi just an update. Checked connections and continuity of lights in main body (can't work out how to get to ones in tailgate)
    anyway all look good and clean with no signs of sooting. After watching a bit longer it has a cycle. All LEDs light up very briefly (tailgate and wing lights then a few seconds later just the ones in the tailgate come on very briefly. (High level one not affected) only one side at a time? Weirder!
  9. Re: Rear LED tail light flicker weird!
    Sep 2011
    Where the warning triangle is located in the tailgate open that cover, then you will see 2 plastic slot head locking elements either side, twist each 90 degrees (IIRC) and then the outer covers where you would assume the rear of tailgate lights to be should come off.
  10. Re: Rear LED tail light flicker weird!
    Begazzz Guest
    Okey dokey. I'll check them tomorrow before I book it in I think as it's such a autonomous rhythmical pattern of flickering it must be a control unit or sumink ....
  1. Led rear tail light repair
    By mrmarc in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 31-12-2015, 06:07 AM
  2. Replacing rear LED tail light cluster (failed LED bulb)
    By vw1967 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-06-2013, 07:29 AM
  3. Replies: 7
    Last Post: 11-08-2012, 10:13 AM
  4. tail light - LED
    By snypa2k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2008, 09:45 PM
  5. Rear LED Tail lights
    By karachi_kops in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-03-2008, 11:32 PM
