Thread: Audi A4 heater problem
  1. Audi A4 heater problem
    Hi All, there seem to be a lot of knowledgeable people out there, hopefully you can offer some advice?
    I have an R reg Audi A4 Avant, only had it about 6 months but now that it's getting colder I've found that the heater is not working - it is blowing but can't get any hot (or even warm) air out.
    Any simple solutions / checks I should do before taking it to a garage?
    Any advice welcome
    Many thanks
  2. Re: Audi A4 heater problem
    Apr 2007
    Hampshire
    What you need to do is invest £15 in buying a vag-com cable on ebay, dowload the software for free from www.rosstech.com and check out whats wrong on the car. It could be anything from the climate control unit, to a motor actuator not opening a flap & letting hot air into the car, or the heat exchanger itself. Do what the garage will do, plug it into a computer & find out that way what is wrong!
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  3. Re: Audi A4 heater problem
    Aug 2007
    Hi Scottie,
    I had this problem as well. I drive around with the car cold most of the time (on my half) and when I came to turn the heating up it didn't get hotter (despite the missus's half of the car working perfectly). I kept the setting on hot for a day and it started working, I think the actuator had jammed. It's been fine since but I'm keeping an eye on it.
  4. Re: Audi A4 heater problem
    Apr 2007
    Lancashire
    If you have 'Aircon', you can use the onboard diagnostics to identify the heater problem:
    http://www.audiworld.com/tech/int5.shtml
  1. Polo heater problem
    By bulkokid in forum Polo - Derby - Lupo - Fox
    Last Post: 25-08-2011, 08:10 PM
  2. 52 Polo SDI - Heater problem
    By Benny2506 in forum Polo - Derby - Lupo - Fox
    Last Post: 18-08-2007, 10:21 PM
  3. sharon heater fan problem
    By woodleggett in forum Touran - Sharan - Caravelle
    Last Post: 30-05-2007, 10:41 PM
  4. heater fan problem
    By doc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2007, 02:01 PM
  5. heater problem
    By paul450 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-12-2006, 06:37 PM
