Thread: Suspension rattle Drivers side
Results 1 to 10 of 12
  1. Suspension rattle Drivers side
    8 Post(s)
    I've now changed top front and rear arms, bottom front and rear arms, c links and anti roll bar bushs, tie rod ends and i'm still getting a rattle from the front drivers side upto 35-40 mph, its better now i've done the arms it's better but still there.
    I have changed the pads on the front but that was a long time before the rattle started and it doesnt go if i'm braking.
    Anyone any ideas on anything else?
    Landrover Discovery 4 3.0 SDV6 HSE
    A6 (C6)Quattro 3.0 tdi Avant Fully loaded Le Mans. Sold
    A6 (C5)Quattro 2.5 tdi(AKE) PP683's & Celtic Remap Sold
  2. Re: Suspension rattle Drivers side
    Pembrokeshire
    22 Post(s)
    top mount ?
  3. Re: Suspension rattle Drivers side
    Chorley
    broken coil spring?
    A6 2007 2.0 TDI Saloon
    A4 2002 1.9 TDI Avant
  4. Re: Suspension rattle Drivers side
    8 Post(s)
    No coil is fine
  5. Re: Suspension rattle Drivers side
    Chorley
    Perhaps the rattle is not from the suspension. What type of rattle is it, light or deeper? When does the rattle happen?
  6. Re: Suspension rattle Drivers side
    8 Post(s)
    I think it's deeper as though something is loose in front, only happens at speeds Upto 40 mph over rough Tarmac uneven roads, no noise over speed bumps etc
  7. Re: Suspension rattle Drivers side
    Nov 2012
    Somerset UK
    Am assuming you had a full alignment done after the arms were changed.
    Based on what you've already changed can you record it, or give an appreciation if it's a metallic or plastic rattle?
    So could be anything from shock mount/undertray loose right through to steering rack, I think that wheel hub wouldn't rattle if worn but will chirp/growl.
  8. Re: Suspension rattle Drivers side
    8 Post(s)
    Under tray is off, c link bolt was 1/2 turn loose which has stopped 80% of what was left, I've noticed there is a small brick in the front chassis rail. I have a 500 mile trip tomorrow/Friday and will see how it goes. Not had it re aligned as place told me to get all the work done 1st.
  9. Re: Suspension rattle Drivers side
    Nov 2012
    Somerset UK
    Quote Originally Posted by jubbly View Post
    c link bolt was 1/2 turn loose which has stopped 80% of what was left, I've noticed there is a small brick in the front chassis rail. I have a 500 mile trip tomorrow/Friday and will see how it goes. Not had it re aligned as place told me.
    1. So are you going to shoot the person that did the links?
    2. Erm how did you miss a half brick?
    3. A 500 mile trip if badly misaligned will show on tyre wear.
    4. Better attention to detail would have saved posters their time
  10. Re: Suspension rattle Drivers side
    glasgow
    35 Post(s)
    The links may be worn, and that's why it was loose ......................... maybe not
    has the noise gone since tightening it up ?
  1. Please Help Annoying rattle drivers footwell
    By Coopsy2728 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-09-2010, 10:14 PM
  2. Replies: 2
    Last Post: 17-08-2010, 10:37 AM
  3. MK5 rattle/vibration from drivers side when slowing down
    By Birdacifa in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2010, 03:42 PM
  4. Passenger side climate control blowing hot, drivers side ok
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2009, 10:44 PM
  5. Please Help Dashboard Rattle near drivers side screen
    By sunil1234 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-12-2008, 01:22 PM
