Thread: Vw audio
  1. Vw audio
    Sep 2007
    Dont know if i have posted in the right place, but here goes. I just recently purchased an 02 passat 130 se. I want to change the tape deck unit ( gamma ) but want to keep the cd player below it in place until i can afford a double din unit. The problem is i want to keep the cd player light up when the lights come on at night does anyone know what wires to add a positive connection to allow this to work. Also what speaker size will fit front and back, are the door cards easy to take off in these.
    Andy
  2. Re: Vw audio
    Oct 2005
    What do you plan to use in place of the Gamma unit? You can usually buy adaptors to keep the factory CD player working so there's no need to worry about wire splicing etc.
    Speakers are 6.75" front and back - 17cm fits nicely but may need an adaptor
    Door cards are fairly easy to remove - from memory (a little sketchy maybe)
    All except driver's door - prise off the small cover over the grab handle and undo the screw. Open the door and undo the two screws under the door - pull the door card up and out being careful to disconnect any wires/plugs/door handle cables
    Driver's door - prise off inner grab handle, lift switch unit up, undo screw there and under the door and the rest is the same as above.
  3. Re: Vw audio
    Sep 2007
    Thanks for that,
    Plan to use a pioneer 75 bt bluetooth head unit it came from my last car and will hopefully use it until i can afford a double din or the wife passes her test then it goes back into her car as i gave it all to her.
    Andy
  4. Re: Vw audio
    BlackVR6 Guest
    17cm speakers front and rear and yes you will need adapter brackets, cant see you being able to run the VW CD changer off the aftermarket headunit as it is controlled by the headunit you are removing.
    I take by your user name you are based in Northern Ireland,If so call up to Sound In Motion, we have a shop in Antrim and one in Campsie near Londonderry, have some good deals on at the minute on kenwood Double din units.
  5. Re: Vw audio
    Sep 2007
    im actually not far from antrim i live in lisburn and will for sure call up at some time, do you work in any of the specific locations. im in 2 minds what sort of speakers to replace the existing ones was thinking of a set of infinity components in the front the same for the rear but want something very easy to hide with regards a sub. or even if i can get a set of speakers in the back doors which are deep and bassy that i can do with out a sub.
    Hope you guys know what i mean.
    until i can afford a double din unit does any one know what wires to add power to in the single disc factory cd player below where i plan to put the replacement cd player. I want the lighting to work when i switch the lights on.
    Andy
  6. Re: Vw audio
    I don't know about pioneer, but Blaupunkt do an adapter to get the dash changer to work with their head units, it's not cheap though at £50.
  7. Re: Vw audio
    BlackVR6 Guest
    Andy I work in the antrim store although I'm in Campsie for the next two weeks. For good sound would recommend JL Audio VR components up front and set of TR co-axials in the back. To be honest you need to put a sub in to get low down bass a set of speakers just won't give you proper sub bass. its something we can discuss when you call up.
  1. Golf Audio
    By Torando_golf in forum Golf MK4 - 1999 - 2004
    Last Post: 07-10-2007, 10:14 PM
  2. Audio upgrade
    By TimS996 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-08-2007, 11:26 PM
  3. A3 usb audio connection etc
    By GeoffT in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-07-2007, 03:43 PM
  4. Audio upgrade?
    By AUDICAB99 in forum 80 - 90
    Last Post: 29-05-2007, 11:15 PM
  5. In car audio question
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 23-01-2007, 10:08 AM
